you should use what ever you feel comfortable with, as you are going to get answers from each ends of the spectrum, and everything in the middle.
Every type of oil you can imagine, someone swears by it, with one consistent factor, they all run. So as long as it is formulated for engine, or transmission use, it should be fine.
