1 members (baldeagle), 40 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#867492 07/17/2012 7:54 PM
jmh
Offline
I am in the process of blasting and priming the hood on my 48 2 ton. The hood is 2 pieces that are riveted. Do I try and separate the hood or paint it whole?
JHolland
Middle Ga
jmh #867534 07/17/2012 10:34 PM
I would not seperate the hood. You should be able to get a nice job with out seperating. I'd take the hood center strip off and do it seperate then after painting the hood put it back on. It will give you a good detailed look.
Achipmunk #867673 07/18/2012 6:12 PM
jmh
Offline
Thanks for the tip. Next logical question is how do I remove the strip? Also I need inner and outer cowl panels for the cab. How big is the job? Can a novice such as myself do it or do I need to spend the money and let a shop do it.
JHolland
Middle Ga
jmh #867681 07/18/2012 6:48 PM
The center hood strip has tabs that are twisted on the under side of the hood.Use some pliers and straighten the tabs and pull it off.
Tim
1951 3100 Chevrolet
bowtietim #867738 07/18/2012 10:19 PM
Several bolters here have replaced the inners, inner to outer, and outer cowl panels. I think it was Weeds that did some major work on his cowling and maybe the dash as well.
If you have some fabricating skills and can weld ect. You can probably do it. However, I chickened out and had a friend in the body business do mine and I have not regretted it. I guess you could say "go for it" just take your time and measure twice and cut once.
