2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | My '40 has a slight smoking problem during acceleration, indicating worn rings. Not ready to tear it apart, so I bought some "motor honey" to try... anyone used this? Is it any good, or a waste of $$$? Thanks.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I've used "Restore"for high milege engines.Stopped blowby.I've tried Lucas products also.Works fine.I'm not sure what product you are talking about | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I'm surprised that stuff is still around. I used it over 30 years ago.At least I was throwing less money away using then, stuff's snake oil like all the other "rebuild in a can" products
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Jul 2012 Posts: 93 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 93 | For your hair?, or your motor? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....I'll just say that not long ago I took up some of the "offers" on the cans and ask for the test credentials and the how the test were run. In plain english it was a joke. The reports they sent back was a shame. The bottom line is they look for the smallest improvement then they can say it does improve without lying. I did this on about 4-5 including some that are mentioned. Send for the info and read for yourself what I'm telling you. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | Thanks everyone for the input. I guess I'll try it, and next oil change try Restore.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Thick oil, motor honey, stp, or stop smoke, all do help to control smoking, to an extent. It is just a band aid though.
I used stop smoke in my bus before I got around to the ring job.
I should have just done the ring job in the first place. I found some NOS rings on ebay for $40, it also gave me a chance to lap the valves and replace the valve seals too. My bus was using quite a bit of oil..... A quart per 100 miles...... Hahahha
If'n yer truck only smokes a bit, the goo might help.
If you aren't using straight 30, and switch to it, you might just find the same improvement! | | | | | Joined: May 2012 Posts: 19 New Guy | | New Guy Joined: May 2012 Posts: 19 | Oil thickeners (and products that swell seals), and thick oil, will quiet a motor down (soundwise) it can slow the smoking from burning oils, they also can rapidly accelerate vital parts wearing because they are simply too thick and do not flow readily (especially on start-up, and also note how your piston wrist pins get oiled). Those products hide the symptoms , they "mask" the problems.
You do not get something for nothing with those products, no such thing as a free lunch, sorry no miraculous cure in a tin can.
If your motor doesn't run right (smokes, knocks) etc with a good grade 10W-30 oil (10W good for lube on start-up) then like Mr. Lang says your just putting on a band-aid ... but one that could worsen the overall wear.
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Been bending wrenches 25 yrs-never seen "mechanic in a can" work as advertised. | | |
