5 members (Oswald, FAST55, Bill Hanlon, 2 invisible), 85 guests, and 2 robots.
Topics128,075
Posts1,055,918
Members48,429
#866956 07/15/2012 9:38 PM
My '40 has a slight smoking problem during acceleration, indicating worn rings. Not ready to tear it apart, so I bought some "motor honey" to try... anyone used this? Is it any good, or a waste of $$$? Thanks.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #866963 07/15/2012 9:58 PM
I've used "Restore"for high milege engines.Stopped blowby.I've tried Lucas products also.Works fine.I'm not sure what product you are talking about
BC52 #867068 07/16/2012 9:44 AM
I'm surprised that stuff is still around. I used it over 30 years ago.At least I was throwing less money away using then, stuff's snake oil like all the other "rebuild in a can" products
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #867095 07/16/2012 11:51 AM
I use Golden Blossom.
panic #867273 07/16/2012 9:50 PM
For your hair?, or your motor?
edski #867303 07/16/2012 10:40 PM
....I'll just say that not long ago I took up some of the "offers" on the cans and ask for the test credentials and the how the test were run. In plain english it was a joke. The reports they sent back was a shame. The bottom line is they look for the smallest improvement then they can say it does improve without lying.
I did this on about 4-5 including some that are mentioned. Send for the info and read for yourself what I'm telling you.
Thanks everyone for the input. I guess I'll try it, and next oil change try Restore.
40casey #867545 07/18/2012 12:21 AM
Thick oil, motor honey, stp, or stop smoke, all do help to control smoking, to an extent. It is just a band aid though.
I used stop smoke in my bus before I got around to the ring job.
I should have just done the ring job in the first place. I found some NOS rings on ebay for $40, it also gave me a chance to lap the valves and replace the valve seals too. My bus was using quite a bit of oil..... A quart per 100 miles...... Hahahha
If'n yer truck only smokes a bit, the goo might help.
If you aren't using straight 30, and switch to it, you might just find the same improvement!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #867626 07/18/2012 1:50 PM
Oil thickeners (and products that swell seals), and thick oil, will quiet a motor down (soundwise) it can slow the smoking from burning oils, they also can rapidly accelerate vital parts wearing because they are simply too thick and do not flow readily (especially on start-up, and also note how your piston wrist pins get oiled). Those products hide the symptoms , they "mask" the problems.
You do not get something for nothing with those products, no such thing as a free lunch, sorry no miraculous cure in a tin can.
If your motor doesn't run right (smokes, knocks) etc with a good grade 10W-30 oil (10W good for lube on start-up) then like Mr. Lang says your just putting on a band-aid ... but one that could worsen the overall wear.
Been bending wrenches 25 yrs-never seen "mechanic in a can" work as advertised.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
