1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
Where can I get an hei dist. for 1953 gmc 228 engine
I think Langdon's can fix you up. He makes them for Chevy's and I think they do the GMC's as well. It's where I and many of the contributors here get them.
www.stoveboltengineco.com
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Crusing in the Passing Lane
Also, wrecking yards, however, make sure the 6 terminals are evenly spaced, otherwise they are for an odd fire V-6, Chevy or Buick. Might have to move the wires around on cap to allow the vacuum canister to fit properly.
They are quite easy to make as well if your interested in going that route. One from a 292 and such is easily adapted to fit, but it can almost be a tight fit against the pushrod cover.
If your looking for one that looks a bit more original, one of the adapted s-10 2.8L ones looks a little more appropriate.
Jeff
My 1953 Chevrolet
1947.1 Gallery
