Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Stovebolt48, Hotrod Lincoln, Lostbuthaulinass, UtahYork), 49 guests, and 2 robots.
Topics128,003
Posts1,055,242
Members48,418
#866520 07/12/2012 10:11 PM
Howdy,
I have decided to replace the outside filler cap with a fuel door on my '69 panel. I have some rust repair to do in that area anyway so why not? what I want is something that uses a pull cable or solenoid from inside. I do NOT want one of the billet things, but rather one from a car or truck that I can cut out in a salvage yard. I know what I need to do to install it safely. What I'm looking for is suggestions for donors and round or square. Remember, my truck is a 1969 C-20 Panel Truck not lowered. Give me some ideas, guys!
many thanks,
Les
Roadmarks #866562 07/13/2012 1:58 AM
Honda civic has an inside release setup
1940 Chevy KC 1/2-Ton
Britcon #866815 07/14/2012 1:20 PM
Depending on where you are going to put the door I would make a template to take with you so you can get as close of a match to the contour as possiable. This saves on the body work down the line. 60-66 Fleetside Chevys a Mitiubtchi PU. door works very well.
I might not of spelled it right for sure but hope you can decifer the Japanese name.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Roadmarks #866844 07/14/2012 11:01 PM
I've used one off a Lincoln Mark VII before, it's round and cable operated (no finger grab recess...)
http://memimage.cardomain.com/member_images/6/web/3150000-3150999/3150740_10.jpg
MPandC #867816 07/19/2012 8:55 AM
Thanks all! I now Have a starting place to begin looking!
Les
