9 members (GMCJammer51, Hawkman, Guitplayer, Uncles51, Dennys28, walterhvogel, Ponchogl, WICruiser, 1955 1 Series),
55
Mod | | | Forums66 Topics128,017 Posts1,055,256 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Howdy,
I have decided to replace the outside filler cap with a fuel door on my '69 panel. I have some rust repair to do in that area anyway so why not? what I want is something that uses a pull cable or solenoid from inside. I do NOT want one of the billet things, but rather one from a car or truck that I can cut out in a salvage yard. I know what I need to do to install it safely. What I'm looking for is suggestions for donors and round or square. Remember, my truck is a 1969 C-20 Panel Truck not lowered. Give me some ideas, guys!
many thanks,
Les | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Honda civic has an inside release setup | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Depending on where you are going to put the door I would make a template to take with you so you can get as close of a match to the contour as possiable. This saves on the body work down the line. 60-66 Fleetside Chevys a Mitiubtchi PU. door works very well. I might not of spelled it right for sure but hope you can decifer the Japanese name. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Thanks all! I now Have a starting place to begin looking!
Les | | |
