2 members (78buckshot, Wheelie),
131
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 26 New Guy | | New Guy Joined: Jul 2011 Posts: 26 | I am the proud owner of a 1941 Chev model 1434 1 Ton. Has anyone ever heard of an overdrive unit for these old trucks? Mine seems to be all it wants to be at about 45 mph. I do have a 4 speed in it now with a working power take-off. Looking for information and parts if anyone has either.
Thanks in Advance 1 Toner | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | There was a 5 speed Clark with OD that will fit, but then you would need a different PTO. An auxiliary is another option, but they are heavy and take up a lot of room. You may can get a later 3/4 ton third member to bolt into your banjo housing. I am not that familiar with interchangeability of 40's Chev. Around 50 MPH is probably all the horsepower and brakes you have anyway. | | | | | Joined: Jun 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 60 | My Dad who is 88 and was young when that truck was new says . And I paraphrase 45MPH was scary fast comin or goin on them roads back then .
Allan 1946 GMC 1949 Mercury M68
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Do you have an open or closed driveline? There are options for both. The biggest bang for your buck is to change the rear gear. You will sacrafice pulling and hauling power for speed but these older trucks usuall don't see the work they used to.
Post which driveline you have so we can get started. Post links to pictures if you can too!
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i can get 50+ out of mine easily with the 228 or the 270 with a 4:56 timkin rear. your out of motor. like cris asked what rear you got? i have a brownie jr od on mine but just took it off due to the noise it makes. i think an overdrive is not worth the gain vs the costs of engineering and installing it these days. i havent done one because im not able to but gear swaps are much cheaper | | |
