3 members (tclederman, DoubleB, Nick in Manitou), 74 guests, and 2 robots.
Topics128,091
Posts1,056,036
Members48,433
it was very very easy actually
ordered the brackets from 5th avenue, they seemed a little cexpensive ($65), but they made the job soooo much easier.
remove the old generator
remove old brackets
tape up old wires
install new brackets(move the upper bracket up one water pump bolt)
install new alternator
I ordered the DA plug with the brackets (15 dollars)
I added a high output 180 amp unit that I bought else where, it is the standard 70's-80's chevy alternator, with the correct pulley alreaedy on it
run the red wire from da plug to the positive battery post on rear of alternator
run 1 4 ga wire from the same post to the positive battery post
and last I ran the yellow wire from the da plug to the green wire on the firewall mounted resistor.
It was actually very easy
Here's the best way to wire it up:
Read This
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
darn wish someone would have showed me this when i was asking about the swap about a month ago. before I did the swap,
I'm actually in Waterloo, not STL
58,
Are you in Waterloo, Iowa? I'm just down the road in Center Point. Also, I work for the Nissan dealer in Cedar Rapids. Small world!
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Junior Member
Junior Member
I have just finished reading the linked page and I am somewhat concerned about that there is no fusible link connected directly to the battery in the line supplying the terminal blocks. I think this added safety precaution would be good insurance.
Hey, Joe
I don't think you want a fusible link on the 8 gauge wire from the battery ... all the connections to the terminal blocks each have their own fusible links -- same difference; better sense.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
I'm in Waterloo Illinois, 25 minutes southeast of Saint Louis MO
Anonymous
Unregistered
Anonymous
Unregistered
Alan, what diode did you use between the ignition switch and the #1 terminal of the alternator? How many amps does it need to handle? I need to install one in my truck as I am getting a slow discharge back through this wire when the ignition is off which drains my battery after sitting for a while unless I disconnect the connector from the alternator. Thanks for your help. Great website you have there.
