10 members (MNSmith, TexasJim50, Hotrod Lincoln, 39Master85, Otto Skorzeny, MarkT, 1955 1 Series, ronsway, tclederman, Snowman51),
94
Mod | | | Forums66 Topics128,164 Posts1,056,978 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 14 New Guy | | New Guy Joined: Sep 2005 Posts: 14 | I need a used or rebuilt front axle for my '53 Chevy PU. I still have the original 235 6cyl. engine and I've replaced the king pins and spindles but the truck still wobbles in the front at low speed and my mechanic says, bent front axle. He also tells me there is no one around anymore who knows how to fix this, without replacement. I'm inclined to take his word as good since he as done so much other work which I know he has done right. Of course I would prefer to find what I need out here in California, but; if shipping is needed so be it. Any help or suggestions would be greatly appreciated Peter | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I'll stick my neck out there and say that if its "wobbling" I don't think its a bent axle....but I can't say its not bent either. You haven't said if you checked the tie rod ends or pittman arm or other steering components. Hey, at this point I'd check to make sure the lug nuts are on correctly and that the rims are not warped ect ect. A good inspection may reveal more. Just my thoughts. Not saying the mechanic is not good but even the best miss something once in a while | | | | | Joined: Oct 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 16 | I have a used one for sale. Real cheap plus shipping if indeed you need it. Pm me and let me know. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Yep, hard to understand how a bent front axle could cause a low speed wobble. It doesn't move, you know.
regards, Leon | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | What condition are your wheel bearings? Any noises heard like grinding or gritty sounds?
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 16 | If the axle was bent in the right (or wrong) place, I can totally see it producing a wobble. For example, if it was bent up or down, just past it's mounting point, I'm sure that it would wobble. I don't know why it would only wobble at low speed though. Could have something to do with centrifugal/gyroscopic forces. Right? | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Wrong. As stated above the axle is the fixed point that the rotating mass spins (wheels, bearings, drums). The only way the axle would wobble is the leaf springs it is attached to move (worn shackles).
To create a wobble one of the entities that rotate are not sound. Those items are the bearings, kingpins, spindle could be damaged, the bearings are not properly tightened, or the drums or wheels are bent/damaged.
The axle being bent could only change the alignment of the contact pad of the tire. In other words if you had premature wear on one edge of your tire, a bent axle could be the issue.
The only way an axle could cause a wobble is if it rotates like your rear wheels.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Oct 2010 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 16 | OH MY GOD!!! You are soooooo right. I don't know that I was thinking. Yes, I was imaging it turning like a tire and therefore wobbling. I feel soooooooo not smart right now. Yes, If it was bent, the tire would still rotate, be it at an angle. In other words, you could not get the camber or the caster right. Hey man, thanks! | | |
