| | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Looking for info for a c notch for my 49 suburban i know they make c notchs for the pick ups but it goes up into the bed area and wont work withthe suburban floor as anyone c notched their suburban or now od a kit that will work if not i may need to make my own out of a peace of pipe but wanted to see my other options first thanks | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | With 43 views...perhaps others are like me. What is a C notch?
| | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | It's a frame-butchering procedure the lowriders do. Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you posted in HiPo shop maybe you'd get answers. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This is how I ended up with a 3rd row original seat for my suburban.The guy slammed his suburban to the ground and had to rework the area under the 3rd row seat and could no longer use it.You might want to check into the low rider sites and ask how they do it,they are a wealth of knowledge and parts.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have no knowledge of this modification, but you most likely have seen This 47-53 rear c-notch kit ? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..."I can see clearly now, the rain is gone"..Johnny Nash 1960's | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Every second issue of Classic Trucks and Custom Classic Trucks has an article on this. The frame for the Burb should be very similar to the half ton and the only difference is that there is a floor to deal with. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | I did NOW THANKS LOL and for what its worth im A LOWRIDER at heart(hope i dont lose points with some of you LOL ) but fan of all things on wheels i dont want to 4 link or bag the back of my suburban but want to get it real low with leafs and blocks if needed in the back with some good air shocks atleast and still keep my 3rd row seat thats why i dont want the more filmilar made notches for the AD trucks because you have to cut into the bed on truck passenger area on suburbans but do want a notch so im not slamming the axle into the frame.But thanks for the link to the notch | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | a c-notch would only be needed if you go to low. i would think the center section of the axle will hit the floor before your axle tubes would. if your going to run it that low a pipe cut in a semicircle would probably work. just make sure you box in around the pipe and not go more than half way into the frame rail. you can see this procedure in most mustang ii setups. good luck mo
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | You're not going to lose any points with me,I say slammmmm it.I like the original,hot rodded,and low rider.They all look good when done right,don't worry about what people think.
The guy I bought my 3rd row seat from bagged his suspension and had to cut out the plywood area under the seat.It really looks good and he had a professional shop do it.I"ll look for some pictures of it on the web and send you a link.
Thanks for saving another Suburban from going to the shredder !!!
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | You're not going to lose any points with me,I say slammmmm it.I like the original,hot rodded,and low rider.They all look good when done right,don't worry about what people think.
Tim Thanks Tim and no problem on the suburban i have always wanted one glad i finally have it LOL heres a pic of kinda the look im after just not sure if im gunna buck up the $$ for the stripes just yet they are any expensive option and i like the suburban a ok without them LOL LOWERED SUBURBAN | | |
