11 members (Otto Skorzeny, Southerntruck, D B Cooper, klhansen, Peggy M, Jims46, Hawkman, manymiles, MikeE, joe apple, 1 invisible), 100 guests, and 2 robots.
Topics128,049
Posts1,055,675
#86329 05/10/2005 1:08 AM
1 Offline
If you had your choice, Which harness would you buy, the one from Chevy Duty for around 100.00 , or the one from Jim Carter for about $140.00. All I want to do is make a good driver out of the '51 ,3100 I bought in Oklahoma last year. I am going to add signal lights and go to an Alterntor. Which is the best signal light switch? Thanks
#86330 05/10/2005 4:30 AM
I wanted to have extra circuits for AC, power seats and anything else that may come up in the future, so I went with an EZ-Wire kit for $160 -- and glad I did.
See my install and Notes Here[/b]
Later, I added some very cool improvements to my entire wiring set up:
[b]Check This Out
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#86331 05/10/2005 5:04 AM
I would go with the Chevy Duty. There basic kit will do the job that you want done. It has instructions and is color coded. Very straight forward. Cecil.......
#86332 05/10/2005 4:19 PM
Would you consider doing it yourself? It is quite simple. I did mine using the schematic and doing one wire at a time. Get good wire and most importantly good crimpers. If you go to 12 volts you can use the wire gauge specified in the schematic.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#86333 05/11/2005 6:11 AM
I bought the Chevy Duty set. I haven't finished installing it completely yet, too many other things going on. But I am very please with it.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#86334 05/11/2005 9:51 PM
I went the route of EZ-Wire and am very happy I did. I also have a daily driver, well when I am not working on it and keeping it off the road, and am very please with the results from EZ-Wire.
-Chris
Chris 1955FirstSeries
#86335 05/12/2005 1:34 AM
1 Offline
I am now leaning toward the Chevy Duty one. I will try and do it myself , so it will take some time. Does the EZ have a web site? Thanks
#86336 05/12/2005 3:07 AM
Click Here -- EZwiring.com
The kit I bought was the 18 Fuse - 21 Circuit Harness for $160 -- see HARNESSES > EZ-21
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
