| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86329 05/10/2005 1:08 AM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | If you had your choice, Which harness would you buy, the one from Chevy Duty for around 100.00 , or the one from Jim Carter for about $140.00. All I want to do is make a good driver out of the '51 ,3100 I bought in Oklahoma last year. I am going to add signal lights and go to an Alterntor. Which is the best signal light switch? Thanks | | |
#86330 05/10/2005 4:30 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I wanted to have extra circuits for AC, power seats and anything else that may come up in the future, so I went with an EZ-Wire kit for $160 -- and glad I did. See my install and Notes Here[/b] Later, I added some very cool improvements to my entire wiring set up: [b]Check This Out
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#86331 05/10/2005 5:04 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I would go with the Chevy Duty. There basic kit will do the job that you want done. It has instructions and is color coded. Very straight forward. Cecil....... | | |
#86332 05/10/2005 4:19 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Would you consider doing it yourself? It is quite simple. I did mine using the schematic and doing one wire at a time. Get good wire and most importantly good crimpers. If you go to 12 volts you can use the wire gauge specified in the schematic. | | |
#86333 05/11/2005 6:11 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I bought the Chevy Duty set. I haven't finished installing it completely yet, too many other things going on. But I am very please with it.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#86334 05/11/2005 9:51 PM | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | I went the route of EZ-Wire and am very happy I did. I also have a daily driver, well when I am not working on it and keeping it off the road, and am very please with the results from EZ-Wire.
-Chris
Chris 1955FirstSeries
#86335 05/12/2005 1:34 AM | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I am now leaning toward the Chevy Duty one. I will try and do it myself , so it will take some time. Does the EZ have a web site? Thanks | | |
#86336 05/12/2005 3:07 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Click Here -- EZwiring.com The kit I bought was the 18 Fuse - 21 Circuit Harness for $160 -- see HARNESSES > EZ-21
