Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, CuzzFuzz), 29 guests, and 1 robot.
Topics128,003
Posts1,055,245
Members48,418
#860374 06/19/2012 2:55 PM
I purchased someone elses project. All the horror stories are true. Among other things I have a rear end with 10 bolts and a number PA 1127 G1 stamped into the axel housing passenger side.
Is there a way to identify what this came out of?
You may have a first generation (67-69)camaro rear end.
You gave us the axle assembly stamp and it could decode as
PA = 3.08 ratio used in 67-69 10 bolt rear ends
11 = month (Nov)
27 = day of month
G = Detroit Gear and Axle plant
1 = 1st shift
To be more sure find the carrier casting number which would be 3894859 if I am right and then find the casting date code which
would end in 7, 8, or 9 if it is indeed a 1st gen Camaro axle.
All info I used taken from this site. http://www.camaros.org/drivetrain.shtml#AxleCodes
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
Thanks Randy,
You are right. I located the casting number as well as a date code of K188.
So now that I know what I have is this a logical unit for a 52 1/2 ton? The engine that came with it is a 216 out of a 53 car matched to a 58 powerglide. That is as far as the PO got. he didn't bother to match up a drive shaft which shouldn't be difficult.
This is not going to be a street scortcher but I don't want it to fight to have to get out of it's own way.
Opinions would be appreciated.
You may want to check the rear end to see if
it is still a 3.08. You only know what it was 44 years ago right now. Hard to tell what a PO has done without checking.
Second, your intended use for the truck will obviously dictate the best driveline. You might do fine hauling light loads and getting around town and highway with your present setup.
If you only get one or two more opinions on your setup, the present discussion title is the problem.
You might start a new discussion in this section with a title such as "216/Powerglide/3.08, Will it work?"
Good luck with your project.
My personal opinion is that if you do have a 3.08 rear, that 216 is gonna struggle to make that truck move. Figure on spending a lot of time in 1st and 2nd gear.
Jeff
My 1953 Chevrolet
1947.1 Gallery
