3 members (tclederman, Guitplayer, 1 invisible),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Hey All
I scoured the site, but didnt find any data specific to bigbolts.
What jack should I be carrying in my 2 ton? I have nothing. I dont need to be original, just functional. | | | | | Joined: Jun 2012 Posts: 33 New Guy | | New Guy Joined: Jun 2012 Posts: 33 | I would go with a "hi-Lift/and or a hydraulic bottle jack. just speaking from a utility and ease of use standpoint.
Homeland defense begins at home.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I would carry a 5 ton bottle jack and some blocks so you can lift either axle a couple of inches off the ground. Make sure you have the correct blocks before you need them. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | I have always used a hi-lift floor jack when I've used my trucks. I got a sears/craftsman high-lift/SUV 6000lb one about 8 years ago and have never had a problem with it. It has the nice feature of a quick lift till it hits the load then it works normal. It is a little heavier and more awkward to carry around then a bottle jack, but it will give you a lower lowered position which can make it much easier to use.
I have used it primarily with my 16' Flatbed car truck, with and without a trailer. I have changed tires fully loaded w/o a problem. I am 8000lb empty on the truck so loaded about 11-12k lbs plus trailer tongue weight....but when you do some math 6000lb is a lot of lift and you should never need more. Even when I am fully loaded lifting the rear duals off the ground is only going to be in the 4000lb range max...and with the high lift jacks you really don't have much need for blocking and a floor jack has a lot more stability than a bottle jack does.(not that you should need it if jacking safely any way though)
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | thanks everybody, I will see if my aluminum floor jack fits behind the seat and if it has the throw to get her off the ground. carrying wood blocks is a great idea. I have a 1960s mercedes limo, which weighs about 6,000 pounds and it has a wooden block about 1 foot square and about 2 inches thick. Its covered in loop pile carpeting to give it a bit of traction.
speaking of behind the seat, what is the filter that is behind the seat on the passenger side next to the gas tank filler? It is a can about 4 inches in diameter with a flat head screw in the top. | | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | A jack stand or two is also a good idea. Especially in these days of cheap, leaky [censored], Chinese made everything. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hey Jay Brown, Welcome!! That "filter" behind your seat would be the breather for your hydro-vac. If you step on the brake,and hear a "huffing" noise for a second,it's the hydro-vac,taking air in through the filter. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | Is there a part number for the actual filter element? i just have the can, no filter.
I just removed the hydrovac to get rebuilt. Is all the vacuum hoses just standard vacuum hose (2 sizes) or is there something special about the vacuum hose. I dont think o, but wanted to ask. | | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | `So are you guys carrying around spare tires and if so, where? Mine's a stake dump, looks kind of limited on placement for a carrier. I don't know where I could mount one, even if I had an extra wheel and tire.
Thanks, D. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | if its a dually you already have your spare. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Some of the trucks had a spare rack that bolted on the bottom of the frame rear of the axle. thus far I have not come across a complete set up. make sure at least one of your jacking blocks has enough size to provide a stable base if you have to do a change on sandy soil.
| | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | I have a partial under-frame spare tire holder on the back of my '46 1 1/2 ton.
Tad
| | | | | Joined: May 2012 Posts: 15 'Bolter | | 'Bolter Joined: May 2012 Posts: 15 | if its a dually you already have your spare. That was my thinking. D. | | | | | Joined: Jun 2012 Posts: 258 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 258 | my spare tire is behind and above the rear end. it took me 2 hours to take it off, the bolts and wing nuts are rusted. the tire is dry rotted too.
and frankly i dont know if i could change a rear tire on uneven ground at night on the side of the road. i might need to install an air compressor and carry an impact wrench. | | |
