| | | Forums66 Topics128,195 Posts1,057,380 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86095 09/25/2003 2:09 AM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Here's a weird one for ya, maybe somebody has a suggestion... Just bought a "reproduction" antenna from LMC Truck, and put it in what I would assume is the right spot on a 51 3100(the hole was there, pass side on the cowl). What a pain to install, had to grind down a bunch of stuff, lousy kit in every way. Worst part is, when I finally finished and opened the hood-rather, tried to. The hood only went up five inches, then the back of it near the windshield slammed into the antenna. What's the stock way and how did they get it to work? Rotten antenna :mad: was 70 bucks, somebody help! As always, thanks for any help!
51 Chevy 1/2 ton-Restored 46 GMC 1 1/2 ton-Farm Fresh
#86096 09/25/2003 2:32 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm not sure of the "factory" way but why not put it in through the side? an antenna from most part houses will mount that way. you have the base coming out of the side horizontally but the antenna sticks straight up. doesn't look bad and is a lot less expensive. | | |
#86097 09/25/2003 4:05 AM | Joined: Jul 2000 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 20 | Dan51, The correct stock location is actually on the driver's side of the cowl. Placement needs to be very precise because the mounting bracket under the cowl attaches to predrilled holes in the inner body panel. We obtained one of the aftermarket antennas and it worked well but it came without the template to drill the 13/16" hole (we used one of those stepped drill bits and it worked very well but you must go SLOWLY). We obtained a copy of the template. Check out this link for a picture of the antenna and a copy of the template. Notice how close the antenna is to the fully opened hood. If you want a xerox life size copy email me and I will snail-mail you a copy. | | |
#86098 09/25/2003 4:14 AM | | Anonymous Unregistered | | Anonymous Unregistered | Yow thats a close fit Lightholder. The antenna placement gets even more complicated if you are runnin' an outside sunvisor. | | |
#86099 09/25/2003 4:24 AM | Joined: Jul 2000 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 20 | Hey MT, we're not so rust free today with ex-hurricane Marty passing over. How much rain have you gotten down Tucson way; we've only gotten about a 10th of an inch so far... | | |
#86100 09/25/2003 6:19 AM | | Anonymous Unregistered | | Anonymous Unregistered | Its been raining for 36 darn hours straight. I am sick of it already. | | |
#86101 09/25/2003 6:49 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Originally posted by Light Holder: Dan51, The correct stock location is actually on the driver's side of the cowl. Not necessarily. My '55.1 GMC has a stock antenna hole in the passenger side of the cowl, and nearly every '54 GMC I've seen is identical. However, earlier GMC and all Chevy through '54 seem to have the antenna mounted on the driver's side. Is there a chance the cab or cowl has been replaced? Dan, you're probably not going to like this, but I went to NAPA and bought the cheapest antenna I could find. Sectional stainless steel with a pivot base, cost $7. No trimming or grinding required, just matched the angle of the windshield and tightened the nut (the hood cleared by 1/8" when fully open). Looked great until a tree grabbed it on a narrow dirt trail, now it's just a stub. :p  | | |
#86102 09/25/2003 9:02 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | When I got my truck the antenna was on the passenger side cowl ... it was a power antenna, and if it was left up -- same thing -- the hood would take it out if opened. That bugged me ... Next was the power part of the antenna was way too visible in the cab ... that bugged me even more! Anyway, the short of it was my decision to put a side-mount antenna on instead ... I bought it from Chevy Duty and am very pleased! I wound up installing it BEHIND the cab, on the driver side though, because mounting it on the side cowl, where it was supposed to go, made it impossible to mount at a nice 90-degree angle. You can see the final result here: Antenna Install
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#86103 09/25/2003 4:40 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | horvath: Nice Truck!! I really like that idea just wondering tho how is your reception? I have power ant. for 59 I cabbage off of our dem. derby car but not sure what I'm reading do I want to do that. popcorn The Truth is Out There (just interested) | | |
#86104 09/25/2003 7:43 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | My 55 1st series had an antenna hole on the driver's side. I filled that in, and mounted a Radio Shack power antenna on the passenger side. Not sure if I am going to have a hood clearance problem (hood isn't on yet) but if I do, the radio will have to be off before I lift the hood.
I have the same Radio Shack power antenna in my 57 chev sport coupe and it works great but took a little work to install it. Also one less hole to punch in the car cover. The truck installation was a snap. | | |
#86105 09/26/2003 3:33 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Popcorn3023 My reception is fantastic! Better than the power antenna was, and I keep the antenna down at 24" ... it opens up to over 6 feet!!! I think this antenna is the coolest look for a truck, too. Be careful if you order one from Chevy Duty ... I just found out that they may have switched suppliers and the new supplier has black plastic mounts. The one I got (just before they switched suppliers) has nice looking chrome mounts. Looks like The Truck Shop has the same one I got ... they're only $18, too!
#86106 09/27/2003 12:25 AM | Joined: Jul 2003 Posts: 106 Member | | Member Joined: Jul 2003 Posts: 106 | Thanks for all the good information fellas. I wonder if Hedgehog is correct about the cab possibly not actually being a 51. The previous owner did 75% of the restoration, and it was already painted awfully nicely, with the antenna hole on the passenger side. I checked caerefully on the drivers side under the dash and it doesn't look like there was ever a hole there...hmmm. The truck was painted four years ago and I'm not sure I'm up to moving the antenna and matching the color and all, so I'll probably wind up using the existing hole and getting either a power antenna or one of those cheapo ones that pivot. Bummer, but cruising on a pretty day, I'm sure it'll be the last thing on my mind! Thanks again!
#86107 09/27/2003 6:57 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The power antenna ain't a bad idea ... just remember to keep it down when you're gonna open the hood. My biggest problem with the power antenna was the motor being so visible in the cab!
