1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well all I am bring it home tomorrow, been costing me $20.00 plus bucks every time I drive out to where the truck is located to work on it.
I will finish the wiring for the lights tomorrow. Finished installing the new 12V battery, 12V generator and regulator yesterday. The AMP gauge works as well as Temp gauge and Oil pressure gauge. Filled gas tank with a couple of additives for water and crud in tank and old gas. Installed new rubber fuel line between gas tank and metal fuel line under cab.
Adjusted the old clutch as good as I can get it, so I can drive it home.
Tomorrow is big day, about a 40 mile trip to drive it home.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | That's probably the most fun thing there is-driving an old truck home under its own power. Hope all goes without a problem. Speed | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I drove it home with almost no trouble... almost.
My foot got in the way and I kicked lose the main power lead to the AMP meter in traffic at a stop light. It starts easy.
Other than that I flew home at an amazing 55MPH (Governed Speed) and 4.5 gallons of gas for 35 mile trip... not to bad in all.
Got a one day moving permit from California DMV, so I was legal.
Either the 302 engine has been totally rebuilt or this thing does not have a lot of miles on it. Speed-o-meter glass is broken and dial is faded and unreadable. No speed-O cable. Absolutely no smoke from the exhaust and lifters are silent.
Brakes worked great, but found one leaky wheel cylinder on left rear...else all went well.
It was GREAT weeeeee.
Now to install new clutch and bearings (release and pilot). And any U-joints as needed for drive shaft and PTO shaft.
I am also totally rewiring the truck every wire in it...found a wiring diagram for GMC 100 - 450 trucks. It gives wire size and color codes.
GMCPic
| | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | WEEE is a good way yo put it!! I took my '55 2nd Series 6500 on her 1st road-trip,(about 80-miles round-trip) over the Memorial-Day week-end! the only trouble I encountered was that the ckoke was half-closed 0n the way to the camp-ground. "Mo'Tater" uses no oil,and with the headers and dual exhaust,"she" gets about 9 M.P.G.-not bad for an old 2-tonner! My 1-ton Dodge got about 6 m.p.g.,but that thing had a gas guzzling 360. Congratulations on your truck!! please keep us posted."Keep on Truckin' | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well it is home now.
I am now tackling the drive line issues.
New clutch, U-joints (3)and carrier bearing if I can find one.
Replaced the U-joints (3) on the PTO drive line to pump.
Replace the broken Hand brake lever with a new one I had.
Had to send the clutch out to have it rebuilt.
Replaced rear trans seal and PTO seals, drained and flushed gear case. Then refilled with 90W gear oil
Need to find a new shift knob.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I am naming truck Blue Bird.
Reason:
After I got the truck home, after a couple of days sitting a Blue Bird made a nest in the front between radiator and grill.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Which pto does your truck have on it? I'm looking to install one on my 470 series COE with 5 spd. Clark. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | The PTO on my truck is the same brand as the dump bed is, The Heil Company. But it sure looks like a Chelsea or it could be made by Spicer.
I can get the numbers off it tomorrow.
Good Luck
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | OK...the PTO Tag Says "The Heil Company" M/N: B4 40
The casting has the name "Chelsea Products Inc", but no P/N or S/N.
Also, the PTO shaft turns in the opposite direction as the trans.
I have the trans hanging from my engine host right now...want pix?
Hope this helps
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | IF you are planning on installing a PTO on the trans be aware that the gaskets for the PTO will come in 2 or 3 thicknesses .10, .20, .30 and may be a .05. Plus the blank cover gasket usually is cork. The gaskets are what shims the PTO for gear backlash clearance.
I pull my PTO yesterday and found that the sliding gear was binding because there was not enough gasket for clearance. I had to add an additional .10 PTO gasket for proper clearance.
You could probably find a PTO in some wrecking yard.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Yes, i'd like a photo or two of your pto. Which side of the trans. is your pto mounted. Thanks | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | The PTO is mounted on the passenger side of the trans, just below the parking brake lever.
It is a two piece unit, the inside piece or part against the trans case has the slider gear that engages with the trans gear. This piece also drops down to offset the PTO output shaft. The outer piece contains the output shaft and shifter fork for the inner slider gear.
BOTH pieces must be properly shimmed to set gear backlash and prevent binding. Proper backlash will help reduce noise and excessive wear.
I will get the pix tomorrow and post them.
I got the trans all painted up pretty, PTO and parking brake too.
GMCPic
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Thanks for the pictures. You have everything looking good. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'm sure it is a Chelsea, now known as Parker. The Heil company never made PTO's although back in the 40's I think the GarWood company did make some for the military trucks for winch use.
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Well I finished installing the Trans and drive lines today. Them old Clark 5 speeds are heavy to muscle around. So now I have a new 11.5 clutch, new PTO U-joints, Drive Line U-joint and carrier bearing. While the trans was out I re-bushed the clutch lever arm and brake arm. And re-shimmed the clutch/brake shaft. Added rubber stops for levers, floor seals for pedals, rubber foot pads, replaced a lot of bolts with grade 8 bolts and nuts Someone had previously really screwed up the clutch linkage, trying to make the wrong release bearing work, rather than replace it with the correct bearing. By the way the new clutch works great, my preliminary clutch adjustments were right on the money. Practice makes perfect, I suppose  Now next comes the exhaust and wiring. Thanks all, GMCPic
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Put on a new 20" muffler yesterday and finished up all the little details for the trans, PTO and related drive-lines. Put the trans floor cover on today with new foam seals and shift and brake lever boots.
Pull the speedometer today, after soaking in kerosene the wheel and needle work freely...saving that issue of rebuilding the speedometer's internal workings.
Tomorrow I am pulling the gauge cluster and replace the decals on it, switch the gas gauge over to a 12v gauge and new temperature gauge (some monkey cut the cap tube on the temp gauge) then start some preliminary wiring, get turn signals working and stop lights.
Then re-wire the 2 speed axle switch from shift lever to rear axle.
I had a drivers side door from a couple of years back, the glass was all in one piece and the window regulator works great.
More to come
