| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 38 | Not having a pattern, just wondering if anyone knows who might be making accurate tank to pump lines for a '50 Burb that's stock? I know I can make one from stock steel, but was wondering if anyone bought one. Jim Carter has a "20 day backorder" and Inline and Classic tube companies don't have patterns. I don't have a pattern to use. | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | If your burb is anything like my 52panel it is pretty straight forward. Once you bend it a little to get it toward the tank the rest can be run right up the rail. Most of the bends needed on the gas line can be accomplished with a hand held bender which is cheap at the local parts houses. The line up the chassis rail can be done pretty much by hand. The short line from pump to carb should be bent a little, fit, bend a little, fit.... and it'll look as good as any.
I personally bought me a 25ft roll of steel line and flared the ends myself. Had one nice long line and the line I had left over I used other places....... Just a thought. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I couldn't find lines for our 66, and if you go to "Uniline" web site, they may have them. None of the catalogs handled them, but Uniline (where some suppliers get them from) shows them available. Worth a try. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | I made my own lines. But then again, I installed a high pressure in-tank pump for fuel injection. | | | | | Joined: Oct 2009 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 38 | Thanks everyone! I will post some pics when I get my tank in and hooked up and running again. It was originally a USAF truck with ID plates.
I will get it up on a friend's lift to do the job easier. | | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | My earlier post was incorrect. I was going off the top of my head, and I missed it. The company I was thinking of is "Inline Tube.com" | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Inline Tubes or Classic Tubes made a perfect line for my 54 Suburban using my original as a pattern. However, that would be of no use for you, because 47-53's line is different from 54/55's line.
