| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 |
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I tend to make my own harnesses. I have used Eno's Custom Wiring Components "Black Box" for my fuse panel as a starting point. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | i got mine at carters for a lot less and it has a sheath over the wiring. i found it to be a no fuss no muss harness. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | i got mine at carters for a lot less and it has a sheath over the wiring. i found it to be a no fuss no muss harness. Did it come with the fuse box? i looked it up on carters web sight but couldnt tell if there was one in the pic and it didnt say in discription | | | | | Joined: Nov 2009 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 35 | I have installed the American Autowire kit in both of my trucks and a few others and like it. It very complete and made in the USA. The instructions are complete and in color. The guys there are Chevy guys and started making Camaro kits years ago. Keep in mind the higer price is because it comes with everything including the headlamp grommets and connectors. The fuse panel is a modern panel and does not use the stock fuse box.
If you want a more orignal look especially under the hood look at the Carter kit. Both companies stand behind their products. | | | | | Joined: Jan 2010 Posts: 7 New Guy | | New Guy Joined: Jan 2010 Posts: 7 | To determine the "best" harness for your build you need to let us know what you are rebuilding. Are you going back stock, 6V, no accessories? Or will it be a V8 powered rod with power seats, windows, AC and a killer stereo? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've used EZ Wire on the 37 and 52. No problems with either. | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | Rick52 i agree i put the american autowire kit in my 57 belair convertible and bought a kit for my 63 impala convertible i was planning on buyingone for my suburban which i probably will do but wwas searching to see if there was a cheaper version of a wiring harness that had most the same features since the suburban didnt come and 24lugnuts i dont plan on running alot of acc's or power options | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What are the features of the American Autowire set that you would like in your 1949 Suburban?
There are less expensive quality sets available (such as Jim Carter's). But JC's and Classic Part's sets do to have many circuits more than an original-circuits set.
| | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | What are the features of the American Autowire set that you would like in your 1949 Suburban?
There are less expensive quality sets available (such as Jim Carter's). But JC's and Classic Part's sets do to have many circuits more than an original-circuits set. I just have had personal experience with the american auto wire kits and they re complete with everything you need all the plugs and light sockets etc they are a nice product i was just wondering what other option where out there and what those kits included | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If all you are looking for is a set that has "everything you need all the plugs and light sockets etc they are a nice product i was just wondering what other option where out there and what those kits included", as stated above, Jim Carter and other reproduction parts sellers have high quality, lower priced wiring harnesses/kits. Thy have everything that is needed to work in a standard equipped truck. They do not have a fuse box (you use your own original one, usually). The American Autowire kit is an upgrade kit - not just a wiring harness. It provides much more than "everything you need all the plugs and light sockets etc". Different harnesses would be used in different 47-55 years. Here are some for 1949: http://www.classicparts.com/1947-49-Wiring-Harness-Alternator/productinfo/52%2D022/ http://www.chevsofthe40s.com/detail...Plastic_Generator_With_Turn_Signals.html http://www.oldchevytrucks.com/cart/product.asp?prodid=EL127C&i=9790||| Those sets above do not tell what are in them, because they have all wires/terminations for standard equipment trucks (unless turn signal leads have been included in the kit). | | | | | Joined: Apr 2008 Posts: 256 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 256 | If all you are looking for is a set that has "everything you need all the plugs and light sockets etc they are a nice product i was just wondering what other option where out there and what those kits included", as stated above, Jim Carter and other reproduction parts sellers have high quality, lower priced wiring harnesses/kits. Thy have everything that is needed to work in a standard equipped truck. They do not have a fuse box (you use your own original one, usually). The American Autowire kit is an upgrade kit - not just a wiring harness. It provides much more than "everything you need all the plugs and light sockets etc". Different harnesses would be used in different 47-55 years. Here are some for 1949: http://www.classicparts.com/1947-49-Wiring-Harness-Alternator/productinfo/52%2D022/ http://www.chevsofthe40s.com/detail...Plastic_Generator_With_Turn_Signals.htmlThose sets above do not tell what are in them, because they have all wires/terminations for standard equipment trucks (unless turn signal leads have been included in the kit). Thanks for the info | | |
