1 members (Peggy M),
121
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | I see a few companies offering gas tanks for 36 trucks on Ebay. 225.00 for steel, an Stainless is way up there 1,200 I think...does anyone have a source for orig size tanks, as these look to be smaller than my old orig tank that was on my suburban. thank you..Bruce D. | | | | | Joined: Nov 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 112 | Try Jim Carter truck Parts in Missouri | | | | | Joined: Sep 2011 Posts: 205 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 205 | Haven't been on the Bolt for a while..and the 36 Suburban is sleeping now due to my Bodyguy away in n. Dak roofing!! It's in primer tho and resy for the final finish. Carter has good repro gastanks? Good..will order. All chrome is finished and resy to assemble..Bruce | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bruce, this says its suppose to work for your burb.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG146&i=|gas tank||
Just copy and then paste the above and it'll take you straight to it.
Hope this helps.
