4 members (klhansen, FAST55, 69Cuda, dt235sd), 120 guests, and 5 robots.
Topics128,050
Posts1,055,667
#846154 04/24/2012 2:07 AM
I see a few companies offering gas tanks for 36 trucks on Ebay. 225.00 for steel, an Stainless is way up there 1,200 I think...does anyone have a source for orig size tanks, as these look to be smaller than my old orig tank that was on my suburban. thank you..Bruce D.
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
mtvoices #848589 05/03/2012 1:24 PM
Try Jim Carter truck Parts in Missouri
oldburbs #858496 06/12/2012 7:19 PM
Haven't been on the Bolt for a while..and the 36 Suburban is sleeping now due to my Bodyguy away in n. Dak roofing!! It's in primer tho and resy for the final finish. Carter has good repro gastanks? Good..will order. All chrome is finished and resy to assemble..Bruce
More pix on Flickr
mtvoices #859151 06/14/2012 10:32 PM
Bruce, this says its suppose to work for your burb.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG146&i=|gas tank||
Just copy and then paste the above and it'll take you straight to it.
Hope this helps.
