2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Well I spent part of yesterday working on the brakes. It was a lot of working, but I'm pleased with the results. Here are some before and after pics. http://s107.photobucket.com/albums/...ent=fc7a3ae4.jpg&mediafilter=noflashhttp://s107.photobucket.com/albums/...ent=cac81fba.jpg&mediafilter=noflashI only got the one set done. Lots of cleanup and prep work, but worth it to make it look better. I also found that Cascade Friction, where I had my shoes relined and got the new wheel cylinders, has a rebuilt hydrovac for $256. That's a great deal I think. I should finally have the engine started this coming Saturday too. So things are moving along.
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy fclaridge, looking good, keep up the good work! | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Thanks 3B. I sure do have a greater respect for these big trucks. I'm so used to working on my Hondas and van. This takes brake work to a new level. | | | | | Joined: Nov 2005 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 43 | I hope your practiced at it I might need advise on my 53 i guess it air over hydraulic.
Jdude
| | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | So, one of my friends looked at my brake job and informed me I needed to grease all the metal to metal contacts points. Makes sense. Can I just use the antisieze I use on smaller disc brake pads? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | there's a brake parts lube that'd be safest, Permatex makes one
Bill | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | I'll check it out. Thanks Red58. | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | For what it's worth, that price on the rebuilt hydrovac is right in line with what I paid for mine. Luckily my core was good, the core charge was almost as much as the hydrovac. Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Beautiful job on the brakes! When would you like to start on mine? And please do follow up with a driving/stopping report. From what I've been told over the years, those monsters may not be state of the art, but do a great job of hauling down a big bolt.
Also...have you replace the single pot master cylinder? If so, I sure would like to hear/see more about it. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Thanks Tango. I just picked up the Hydrovac this morning from cascade Friction in Tacoma. Great guys there. They can get me a brand new master cylinder for $101, it's a Raybestos part MC21680. So I'll get that ordered pretty soon. They did not show a listing for the from wheel cylinders, so will be looking more for that. Jim Carter has them for $62 each, but want to check around some more. I think there are guyst that have posted some resources for parts so will be searching the threads. Cool looking bus by the way.  | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | If you are looking at $62 each for cylinders you might want to look into getting yours sleeved with stainless liners. Cost might be a little more than that...but then you won't have to worry about rust again. Just something to consider.
Tad
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Jun 2012 Posts: 13 New Guy | | New Guy Joined: Jun 2012 Posts: 13 | I noticed you had a new spring for the brake return spring looked like what is the part number for that? I am warking on a 53 gmc 353-24 and one bent on me putting it back together. Thanks in advance and great job there looks like | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | Jungerfrosch, something to think about for sure.
Randy0563, the springs aren't new. I just sandblasted all the rust away and repainted them. Sorry. | | | | | Joined: Jun 2012 Posts: 13 New Guy | | New Guy Joined: Jun 2012 Posts: 13 | O ok i will continue my search than
