| | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | This is a part from a 49 Chevy Panel truck, model 3100. I think it goes somewhere underneath the truck, but I don't know where. Can you identify the part and let me know where it bolts on and what does it do? Thanks for the help. Photobucket God bless, Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would say it is not a GM original. Maybe a fender brace?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Almost looks like part of a hitch mount. An angle brace from the rear cross member down to the draw bar. 1 of 2.... Just a guess...
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Thanks for the help, I appreciate it.
Dave
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | it's a floor to frame brace for whatever was mounted in the back of the panel, Scott | | | | | Joined: May 2007 Posts: 222 Shop Shark | | Shop Shark Joined: May 2007 Posts: 222 | Scott:
Is it a Chevy part or an added part, and more in particular, where does it go. Thanks.
Dave
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If there was a large tank or generator or a pump or whatever mounted on the wood floor of the panel, those braces went under the wood floor to help support the item and then attached to the frame. It was made by the outfitting company that installed the equipment. I found those braces under a 1 ton panel I did some chassis work on. It originally had something like a generator in it from the Gulf Oil company. Look in the gallery under 47.2 Chevy's. It's Brad Birdnow's panel, Scott | | |
