5 members (dt235sd, Toadwart, Chip O, 2 invisible), 106 guests, and 1 robot.
Topics128,087
Posts1,055,998
Members48,430
#856339 06/04/2012 12:18 AM
This is a part from a 49 Chevy Panel truck, model 3100. I think it goes somewhere underneath the truck, but I don't know where. Can you identify the part and let me know where it bolts on and what does it do? Thanks for the help.
Photobucket
God bless,
Dave
Joh 3:16 For God so loved the world, that he gave his only begotten Son, that whosoever believeth in him should not perish, but have everlasting life.
A49ER #856380 06/04/2012 2:49 AM
I would say it is not a GM original. Maybe a fender brace?
My Blog
Almost looks like part of a hitch mount. An angle brace from the rear cross member down to the draw bar. 1 of 2....
Just a guess...
Thanks for the help, I appreciate it.
Dave
A49ER #857163 06/07/2012 3:16 AM
it's a floor to frame brace for whatever was mounted in the back of the panel,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Scott:
Is it a Chevy part or an added part, and more in particular, where does it go. Thanks.
Dave
A49ER #857674 06/09/2012 4:14 AM
If there was a large tank or generator or a pump or whatever mounted on the wood floor of the panel, those braces went under the wood floor to help support the item and then attached to the frame. It was made by the outfitting company that installed the equipment. I found those braces under a 1 ton panel I did some chassis work on. It originally had something like a generator in it from the Gulf Oil company. Look in the gallery under 47.2 Chevy's. It's Brad Birdnow's panel,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
