8 members (Wally / Montana, Donf, DoubleB, Otto Skorzeny, tclederman, BillCollins, C10 - C90 Bill, HandyAndy),
57
Mod | | | Forums66 Topics128,090 Posts1,056,022 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 24 New Guy | | New Guy Joined: Apr 2012 Posts: 24 | I have a 63 chevy c10 and i have found a 64-66 chevy cab. Will there be problems with the mounting and all? Or anything i would need to do with it? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | 63 cabs are completely different from the others. As long as you don't expect to use doors and glass between the two, mounting should be easily doable, Scott | | | | | Joined: Jan 2009 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 175 | 63 and 64 was a HUGE change in GM trucks different cab, different frame the grille and the tail gate will change over as far as tin goes, the rest is gonna be a problem. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Not so fast: The big frame changes took place between '62 and '63.
Fenders, hood, inner fenders, grill support, box, bumpers will all work.
clutch linkage, brake lines, steering box and linkage and radiator are also the same from '63-up.
The rear end is a 1-year old rear end housing, mainly because of the length of the panhard bar and it's mounting bracket.
I'm almost certain the floors are the same from '63-'66, which means the cab mounting points will be the same too.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The frame rail widths and the front frame-to-cab perches and rear frame-to-cab perches, are the same from '63-'66, so the 4-5-6 cab will fit properly on the '63 frame and the support bolts will drop properly.
