| | | Forums66 Topics128,114 Posts1,056,605 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | http://s1073.photobucket.com/albums/w386/David47619?? gmc coe stored inside last 25 years. almost all here. very little rust. 205119.7by STAMPED on block AFR722 ON TAG UNDER DASH
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | A=1939 and up truck F=COE R=Tractor 722=720 Series
This will be a 1939-1948 model, 136" wheelbase, 14" clutch, 426 engine.
Hope that helps some. I'll look for some more info.
Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | There should be an ID number stamped on the frame or written in chalk, on the passenger side, directly behind the front spring perch.
Jeff | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | TAG SAYS 128 H.P. INLINE 6 SINGLE BARREL UP DRAFT CARB | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | It looks likes a 31 following the serial number on the ID plate which would also indicate a 1941 model year.
Jeff | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | CANT SEE ANYTHING ON THE FRAME
| | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | 314 indicates a 1947 model year.
Jeff | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | According to the Master Parts Book, there may be a plate attached to the engine on the drivers side with details including engine serial number, bore, stroke and cylinders.
Jeff | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | 4265853 BORE 4 1/4 STROKE 5 CYL 6 | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i looked at the 47 you have pic posted, grills are diff? did they make more then 1 style back then? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Yes. That truck is one of the largest available Road Tractors GMC made at the time. It would be called a 5 1/2 ton or more if memory serves me.
The 426 in the serial number confirms it is a 426 engine.
Jeff | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | Is it worth more then scrap? I dont see many old trks out there. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | It's worth a hell of a lot more than scrap. COE's are difficult to find and the road tractors are even harder, plus the pics look like it is in great shape.
Jeff | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | WOW !, That's "AWESOME". You can always tell the later '46-'49 Heavy Duty COE's from the earlier ones, by the hood. The later '46-'49, have a split two piece grille, with a "alligater" hood, while the earlier one's have a one piece grille, with two access doors, instead of a opening hinged hood. That 720 series would be around a 6, or 6 1/4 ton. | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Why are these dang things always on the wrong coast? You never see anything like that around here. Nice truck!
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Scott,I've always thought the same thing. You don't find the '47-'54 450, & 470 series COE's on the East Coast either. In the 26, or 27 years, that i've been collecting COE's, i've only found one 450, or 470 series COE in North Carolina, & one in Virginia. The one in North Carolina was a '53 model that had been damaged badly, & the one in Virginia was tied up in an Estate. I found the 450 you have in Indiana, & the 470 I now have, came from Washington State. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Spanky, they got so many nice trucks out there that they consider scraping them!! Just kidding David, but that is an awesome truck. I would snatch it up in a second. | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | my last thought is to scrap this truck!! sounds like most are collected back east. can anybody give me some kind of value. I work at a trucking co.ANYTHING CAN BE SHIPPED!! Boss has had truck stored inside a trl for last 25 + years. I think it's all here? missing back window. i have couple boxs of small's. i've seen some pic's of restored trk's that are amazing!! We turned the motor, not froze. NEEDS TO GO TO SOMEONE WHO WILL SHOW IT SOME LOVE. EVEN IF THE BOSS ONLY GET'S SCRAP VALUE. THAT'S MY THINKING. dont know if the boss is on the same page | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I'll buy it for scrap value!  If I had the time and coin, I would buy that thing in a heartbeat. Prices are hard to define. Having a clear title is a must, but if you find the right person it would sell anyways. I think I paid around 4K total, delivered, across 2600 miles or so for my '47.1 One thing to think on is that the gross vehicle weight of 30K requires a CDL to drive. The condition looks amazing from just the few pics and those fenders are probably some of the best I've seen. I hope it finds a great home and isn't butchered by some 'car hauler'... Jeff | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | pic's of your trk are great. looks like you need another project. I wish I knew where this trk came from,what it was used for. somebody took very good care of, before it was parked | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Man that truck is awesome! Would it have air brakes? I would love to hear an audio of the engine roaring to life. | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | it does have air brakes. I dont know if truck runs. it's been stored for last 25 + years in a trl. radiator is not in. motor turns that's all i know. i think its all here. no back window!! very minor rust. all dash pane1,gauges,glass shift spliter, everything is still good in the dash. plaque is there | | | | | Joined: Sep 2011 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 70 | That truck looks very much like one listed on ebay last fall, it was near San Francisco. He had it listed as a '39 GMC if I remember correctly. | | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | I dont know, but I think Mr Marlow needs a big brother for his 46, with the same color scheme!
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Jeff, you're killing me! As stated, I would love to have it and do just that. The problem is the distance between where it it and where I am. You would have a lot of money in it as soon as you back it in the garage the first time by the time you paid the shipper. A fellow can dream though can't he? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Billy,
Maybe someone going to the Diesel Confab at Grigg's? I have storage space for a short rest at my place.
| | | | | Joined: Jul 2008 Posts: 413 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 413 | That would look awesome though,
How bout it Spanky, this one is a Fine COE!
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | It's nice, but I finally found the style, & series I was looking for, when I found my '52 model, air brake 470 series GMC COE. It's actually alittle more "Rare" than this one. It was located in Washington State, but I was able to find an inexpensive ride for it to the East Coast. | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i need to find a home for this truck. somebody call me 951-377-0430 | | | | | Joined: May 2012 Posts: 271 'Bolter | | 'Bolter Joined: May 2012 Posts: 271 | wow.. i wish.... that is a BEAST! | | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i found out trk was used by the forest service, that is why color is Yellow w/ Gray fenders. old color's back in the day?? | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | One thing to think on is that the gross vehicle weight of 30K requires a CDL to drive. The condition looks amazing from just the few pics and those fenders are probably some of the best I've seen.
Jeff [/quote'"
I don't think a CDL would be required as long as it is registered as a antique. CDL is for Commercial vehicles. In the wieght class on my 38 Registration it has NA. You would be best to read your states rules. There used to be allowences to drive a bobtail commecial vehicle on a car license but that may have changed, you couldn't pull a trailer and you couldn't drive a unladen straight truck.I hope someone saves this truck
| | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i hava a offer of $5000.00 for just the cab section. would like to sell complete. if it gets parted out, will be harder to sell what's left. | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Sell it as a complete truck only! nice truck! http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy davidVAL, do you have a clear title for the truck? You mentioned the radiator is not in place, do you have it? My vote is also to sell the truck complete (not that I have a vote), I just would like to see it kept together. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | remember that an old truck is worth is what a buyer will pay  take the 5thou before that person comes to their senses and you have to 'sell it complete' to the scrapper for a few hundred Bill | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | In CO, anything weighing more than 26,000 requires a CDL, farm tags exempt, however, no out of state, not more than 150 miles from home, don't know how well this is enforced.
| | | | | Joined: May 2012 Posts: 17 New Guy | | New Guy Joined: May 2012 Posts: 17 | i do have radiator. only thing i know is missing is back window. have no paperwork???? | | |
