5 members (Otto Skorzeny, Shade Baby, DadsFirstPickup, greenie-reddy, Wayne67vert), 115 guests, and 0 robots.
Topics128,147
Posts1,056,798
Members48,454
I have a heater core which has an integral cable operated control valve.The valve itself is leaking.Is this valve available separately from the heater core?I've looked and can't seem to locate a heater core complete with valve or just the valve itself.Any help would be appreciated.
here is a link to answer any question you can think of.
http://www.heatercontrolvalve.com/
jake Groby
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Its probably the Ranco heater control valve which is bolted to the heater core. They have not been reproduced. I had the same issue with my 63 about 6 months ago. There is only 1 guy I know of that rebuilds them....Ill find the address.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
heatercontrolvalve.com he does nice work and gives a warranty. Your only option is to go with a different core and an external control valve in your engine bay. He can rebuild it and you can retain all your factory appearance and controls.
modelman....by the timeline, you were typing at the same time as me. oleschool...this is the best option in my opinion
The valve is a separate piece. Not available new, but used/nos ones turn up on eBay. There is also a repair kit available from the suppliers that may fix the leak. FYI, the heater core isn't available either, although many suppliers list it. I bought the listed one and had a radiator shop switch the tank on the side with the valve.
FYI there is a 'NOS valve on eBay right now.
