| | | Forums66 Topics128,120 Posts1,056,649 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 24 New Guy | | New Guy Joined: Apr 2011 Posts: 24 | I have a heater core which has an integral cable operated control valve.The valve itself is leaking.Is this valve available separately from the heater core?I've looked and can't seem to locate a heater core complete with valve or just the valve itself.Any help would be appreciated. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | here is a link to answer any question you can think of. http://www.heatercontrolvalve.com/jake Groby | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Its probably the Ranco heater control valve which is bolted to the heater core. They have not been reproduced. I had the same issue with my 63 about 6 months ago. There is only 1 guy I know of that rebuilds them....Ill find the address. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | heatercontrolvalve.com he does nice work and gives a warranty. Your only option is to go with a different core and an external control valve in your engine bay. He can rebuild it and you can retain all your factory appearance and controls. | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | modelman....by the timeline, you were typing at the same time as me. oleschool...this is the best option in my opinion | | | | | Joined: Jan 2010 Posts: 45 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 45 | The valve is a separate piece. Not available new, but used/nos ones turn up on eBay. There is also a repair kit available from the suppliers that may fix the leak. FYI, the heater core isn't available either, although many suppliers list it. I bought the listed one and had a radiator shop switch the tank on the side with the valve. | | | | | Joined: Jan 2010 Posts: 45 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 45 | FYI there is a 'NOS valve on eBay right now. | | |
