7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible), 123 guests, and 1 robot.
Topics128,095
Posts1,056,072
Members48,433
#854478 05/27/2012 7:48 PM
I see alot of beds on older and not so old trucks that are crooked.Does anyone know what causes this?Reason I ask is I just bought my first truck last week (66 gmc) and its nice and straight and Id like to make sure it stays that way.Also if this does happen,what is a good remedy to fix it?
Kain #854494 05/27/2012 9:11 PM
The older trucks use 2-1/4" tall wood blocks that have bed bolts running through them to support the bed. When these rot away or wear out they sag. Also cab mounts wear out making the cab lean further compounding the look.
Brad Allen #854544 05/28/2012 1:32 AM
Some trucks have been so abused that the frames can be tweaked just enough so the bed isn't square when you measure both diagonals even though everything looks fine. This is mainly with the newer trucks that have a bed mounted directly to the frame, such as '60 and newer unless I'm mistaken.
Otherwise, there can be any number of tiny things that can cause it right down to a worn suspension on one side.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Brad Allen #854637 05/28/2012 2:42 PM
Haha. All the wood blocks on my '52 are gone. The bed is being support by the floor boards directly in contact with the frame axle "hump". The saggin bed caused the bed to rub a hole in the top of the filler panel between running boards and bed. Not to mention all the strain and cracking to rear fender sheet metal at running board connection.
