0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I am rebuilding a "52" 3100 with a cab that needed a fair amount of work. Part way thru my rebuild I found a "48" cab that is rust free and am going to use it. Problem is I have all the weather strips, window channels and glass for my "52" doors including the wing windows rebuilt. There is a difference in the latches between the two years. Will the "52" doors work on my "48" cab or should forget what I have put into them and use the "48" doors. Thanks
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Apr 2012 Posts: 35 New Guy | | New Guy Joined: Apr 2012 Posts: 35 | The doors will fit, BUT the door latch & striker plate in the door jam may be different(they changed in 51-52). But I am sure someone here has done the swap & may chime in.
An elephant is a mouse built to government specifications.
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | Sounds like a good time to install Altman Easy Latches. . .
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have not done it but it has always been my understanding that if the striker plate matches the same year as the door latch you will be OK. | | | | | Joined: Aug 2008 Posts: 290 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 290 | You can use your doors with the same latches but you'll have to use the earlier striker plate as the newer one will not fit in where the plate goes. Also make sure you test fit your door before you do any painting, that way if you have to trim your cab or door it's before hand. Also make sure that when you are fitting the door that the stiker plate is NOT installed you will just be chasing your tail trying to get it to look right. Anyway I hope this helps. I did the same thing to my 53(twice). Check pics out. Laters
