1 members (UtahYork), 108 guests, and 2 robots.
Topics128,049
Posts1,055,679
#852558 05/19/2012 1:32 PM
can anyone please advise on tyre pressure for a 49 1/2 ton with 7.00 x 15 tyres?
wak1963 #852562 05/19/2012 2:00 PM
40-48 psi, depending on the load?
What is the ply rating?
Radial or Bias ply?
I would start at 36psi and drive it at whatever will be be your "normal speed" and road-type.
Then, add 4 psi and do another drive.
Repeat.
Go with the psi that provides best balance between good tracking and ease of steering (without excessive wandering).
I think I ran 7.00x15" Toyo radial tires on a 54 1/2 ton pickup at 45 psi.
Usually the tire manufacturer will provide a load vs psi chart for each style/size tire.
tclederman #852597 05/19/2012 4:00 PM
these are cross plys it wondered badly at 30psi im now down to 20 it seems better the lower it gets ?
wak1963 #852630 05/19/2012 5:06 PM
Don't your tires have the suggested rating on the sidewall?
That low of the tire pressure presents a much more dangerous issue to drive. If they wander, most likely there is something else at work causing the truck to track crookedly.
Jeff
My 1953 Chevrolet
1947.1 Gallery
wak1963 #852640 05/19/2012 6:12 PM
Leo Offline
Moderator
Moderator
Mine wanders too, depending on the road. Tall skinny bias ply tires will do that.
I have 36 psi in mine because that is what is printed on the sidewall.
wak1963 #852647 05/19/2012 6:31 PM
Ex Hall Monitor
Ex Hall Monitor
Chevy recommended 24 PSI front and rear.
Tiny #852708 05/19/2012 10:52 PM
Chevrolet recommended a few different PSI for 4 different 15" truck tires , depending on the tire (as high as 48). Tiny's link is for a passenger car tire/load.
No 7.00x15" is listed, so checking the PSI at different loads given by the tire manufacturer might be a good place to start?
The 1949 Truck Data Book shows a variety of PSI for each size of 15" truck tires, depending on the load.
tclederman #853043 05/21/2012 5:26 PM
I am running 650-16 bias-ply at 28 psi. Nice ride and even tire wear. I recall as a kid all tire sizes (no radials then) seemed to warrant 28 psi. When radials came along we were surprised to have to bump them up to 30+ psi.
Bias-ply will wander in ruts or grooves. I have Firestone on my 49 and as I have written before I love them. They are new and the compound is much different to the old bias-ply. They do not flat spot and run very smoothly at speeds up to 55. Don't know above that as I have not tried it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
rustednuts #853123 05/22/2012 1:15 AM
The pressure rating on the sidewall is the maximum pressure the tire is rated for, not the suggested running pressure. The best bet would be to either check the owners/shop manuals or the tire manuafacturers suggested pressures for a given weight capacity.
Bill Burmeister
