| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#85208 10/10/2004 3:43 AM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | I just had this sudden urge to rewire my truck. I seen several of you have used the EZ-Wire kit. Has anybody used the kit from Painless? There's nearly $200 difference. I've been bit more than several times by the "get what you pay for" bug, and don't want to invest a lot of time in a cheapo harness. Has anybody installed both harnesses, and can say one is better than the other? Does EZ-Wire label each wire like Painless does? Is there any quality difference between the two? Does anybody prefer the mini fuse over the regular fues kit? Thanks for any input! | | |
#85209 10/10/2004 12:26 PM | Joined: Apr 2004 Posts: 31 Junior Member | | Junior Member Joined: Apr 2004 Posts: 31 | Howdy, I've used a Painless 18 circuit harness, with provisions for the later model, tilt, GM steering column that's installed, for my 1964 Carryall... The quality is excellent, was very easy, just tedious, to install... Any harness is tedious... All wires are clearly marked throughout its length... I'd say the Painless harness was worthwhile, even though expensive, since tech responses were very fast and helpful... Everything worked and I have pre-labeled circuits if I chose to add options... Summit Racing had the best prices when I bought mine... hope this helps... Later
Pete in NE PA 1964 Cheverolet Carryall 1965 GMC 1/2 ton
#85210 10/10/2004 8:23 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | The guy who turned me on to EZ-Wire had installed numerous Painless kits and a couple of EZ-Wire kits ... he told me they were the same except with EZ-Wire you have to buy your own ground wires (I just bought a roll of black wire -- see my link below). EZ-Wire kit labels each wire every 6-inches or so; same quality as painless. I wired my truck a year and a half ago ... no problems; easy install. See Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#85211 10/10/2004 11:35 PM | Joined: Oct 2003 Posts: 54 Member | | Member Joined: Oct 2003 Posts: 54 | I was thinking of going with the mini fuse harness, so it would match the harness for my engine (95 TBI). Is this a good idea, bad idea, or does it really matter? Thanks. | | |
#85212 10/13/2004 10:08 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I don't think it matters. A 10 amp fuse is a 10 amp fuse, ya know?
#85213 10/14/2004 3:00 PM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I used the Painless on my 37 pickup. Work great and I have had no problem in 4 years. What I know about wiring you could put in a thimble so it had to be easy!!! | | |
