| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | I have what appears to be a manual foot operated washer fluid pump on the firewall above the high/low foot switch. Does anyone know how to take it apart? The pedal pad and the pump just spin on the rod ends. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Here is a picture of my NOS pump, inside the button is a clip that holds it onto the shaft. If you grasp it carefully with water pump pliars it will pop off. You then undo the special collar nut and it should go through the firewall. http://good-times.webshots.com/photo/2420614510102454676VxIBzr | | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | Thanks for the post Brad. I wish I had seen it earlier. I finally figured out that the clip was holding it on (used a little mirror to see it). Your pix are just what I need to figure out what my truck is missing and how exactly the pump works. Looks I'm gonna need to order some parts.... | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have the original instructions that came with my NOS set-up, I sent a copy of the pdf to your e-mail. | | |
