1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#850981 05/12/2012 4:49 PM
I have what appears to be a manual foot operated washer fluid pump on the firewall above the high/low foot switch. Does anyone know how to take it apart? The pedal pad and the pump just spin on the rod ends.
Here is a picture of my NOS pump, inside the button is a clip that holds it onto the shaft. If you grasp it carefully with water pump pliars it will pop off. You then undo the special collar nut and it should go through the firewall.
http://good-times.webshots.com/photo/2420614510102454676VxIBzr
Thanks for the post Brad. I wish I had seen it earlier. I finally figured out that the clip was holding it on (used a little mirror to see it). Your pix are just what I need to figure out what my truck is missing and how exactly the pump works. Looks I'm gonna need to order some parts....
I have the original instructions that came with my NOS set-up, I sent a copy of the pdf to your e-mail.
