5 members (fonz8261, Phak1, CATMAN, Shade Baby, CharlieF), 60 guests, and 4 robots.
Topics128,153
Posts1,056,842
Members48,456
So my 261 is almost finished and before I put stuff on it permanently I have a question about thermo switches to power an electric fan.
I made a spacer to go between the water inlet and the block where I always plumbed a water line to go to my intake manifold. Wile Im here I thought I should drill it for a switch as well.
What are people using? I was thinking a switch that kicked on at about 205 and off at around 190 F.
Thoughts?
A m I crazy?
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
I'm using a switch on my '56 that is wired into the electric temp gauge unit. It can be set to come on when you want it.
Where did you get your switch?
Where did you install it?
So you are using it as a temp sender to the gauge and a switch for the fan? That's pretty cool.
what temp did you set it for?
Jeremy
More pix on Flickr
I got it at Speedway.
I have it mounted under the dash on the steering column.
This wires to the back of the gauge. Use your existing gauge and sender.
I have mine set to come on at 180.
Got mine stuff for the fan from Speedway to. Good folks. I have my fan coming on at 195 for my V8 and I also have a manual switch to if needed.
Flexalite makes a probe that slides between the fins of the radiator, along with an adjustable controller that lets you set your on / off temps. Works great / no holes req'd in hoses or fittings. Most speed shops carry this item.
1940 Chevy KC 1/2-Ton
