1 members (Hotrod Lincoln),
118
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | So my 261 is almost finished and before I put stuff on it permanently I have a question about thermo switches to power an electric fan. I made a spacer to go between the water inlet and the block where I always plumbed a water line to go to my intake manifold. Wile Im here I thought I should drill it for a switch as well. What are people using? I was thinking a switch that kicked on at about 205 and off at around 190 F. Thoughts?
A m I crazy?
Jeremy | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm using a switch on my '56 that is wired into the electric temp gauge unit. It can be set to come on when you want it. | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Where did you get your switch? Where did you install it? So you are using it as a temp sender to the gauge and a switch for the fan? That's pretty cool.
what temp did you set it for?
Thanks, Jeremy | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I got it at Speedway. I have it mounted under the dash on the steering column. This wires to the back of the gauge. Use your existing gauge and sender. I have mine set to come on at 180. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Got mine stuff for the fan from Speedway to. Good folks. I have my fan coming on at 195 for my V8 and I also have a manual switch to if needed. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Flexalite makes a probe that slides between the fins of the radiator, along with an adjustable controller that lets you set your on / off temps. Works great / no holes req'd in hoses or fittings. Most speed shops carry this item. | | |
