2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
Got my tank out (broke a mount bolt too, boo), took the sending unit out and it appears to be rusty on the inside. There was about 2 inches of gas still in the bottom that has been probably sitting for 2 - 3 years.
PIC OF TANK HERE
Any suggestions? It's pretty hard to see in there.....
-Troy
Old gas tanks arent worth messing with if a new one is available, I always go new,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
get a new tank
It comes down to what are you into as far as messing with your old truck. 48 BigT is into swapping in new tanks, I'm into the original equipment angle on mine because it's 90% there. I'm into the idea of restoring others are drivers pure and simple.
I replaced the float on my sending unit(from NAPA)but with lots of research and elbow chemicals the mesh screen and all the rest came out nice, clean and ready to go again, plus I learned a bit about how they engineered things.
For the tank I found a 20' chunk of chain and a few shovels of pea gravel worked well, followed by hose off the hot water heater through the pressure washer and finished with an hour of shop vac blowing things dry. YMMV.
It's quicker to replace than restore that's for sure.
Give me ambiguity
or give me something else
Once you have the rust formed in the tank its very difficult to get it clean. I have had them derusted in a tank of caustic chemicals, then used the tank liner products available. It looked good when I was done and worked fine. I talked to the guy who purchased the '34 and 20 years later he had a rusty mess and ended up replacing the tank. So if you decide to clean yours I'd suggest giving it a visual inspection every couple years.
I went to a lot of trouble to salvage my old tank and spent almost as much on chemicals for it as a new tank. In the end I still wasn't happy and got a new tank. One of my better decisions.
Chuck
Once you have rust, you always have rust!
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Buy yourself a Spectra Premium tank. They are made in Canada and fit like originals. Then you will be done with the gas tank problems.
Have you got a link on where to purchase a Spectra Premium Tank??
Need one for the 41 1/2 ton. Looked at cleaning and discovered that there were 2 baffles in the tank, so the chain route dosen't work to well.
Thanks in advance: Kirk
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
A new tank is the only way to go. Bought mine from Jim Carter. Expensive, but I am driving now without fuel problems.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
