10 members (Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M), 104 guests, and 2 robots.
Topics128,038
Posts1,055,471
Members48,424
#846696 04/26/2012 3:24 AM
Is there some sort of secret way to take the interior door handle and window wind up off? I've undone the screw and tugged a bit, but i don't want to tug to hard and brake something
Josh
RUST, and 60 or so years of krud. Spray with some lube, wait a few days and repeat. It will come off! Make sure the screw is backed out enough, or just take it out all of the way.
....David
I believe there are TWO screws on the interior window handle, or the door latch handle, I can't remember which. One covers the other. Check inside the hole to make sure.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
I had the same experience Tom describes. 2 screws. I had the door off when I removed mine or it would have been pretty hard to see the second screw.
Chuck
Alright, ill look for the second screw and spray with WD40 while im at it.
Thanks for the info!
So after cleaning out all the crud that was behind the first screw, i found the second screw... now to find a small enough screwdriver to fit
....a long slim screwdriver seems to work better for me.
Sears sells a professional series driver that is perfect for this job best $13 I ever spent.
Craftsman Professional Screwdriver 1\4 in. X 12 in.Sears Item# 00947165000 | Model# 47165
I had a bunch of old, cheap screwdrivers laying around, so I took the skinniest one and ground it down to fit. That old wooden handled thing comes in handy for a lot of odd jobs.
1948 Chevy 1/2-Ton
I've got the same problem on my 50 AD,I guess i'll need to look for those second screws today.
EDIT.Found them!
More pix on Flickr.
Moderated by  ndkid275, Phak1
