Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (ShopRag, 46 Texaco, Shade Baby), 147 guests, and 5 robots.
Topics128,283
Posts1,058,521
Members48,490
#847120 04/27/2012 7:03 PM
Hi,
I am hoping for some help identifying this tranny.
My best guess is a Clark 264VO. It bolts up to GM bell housing and has a 10 spline (1 1/8" shaft). Compound low is about 6-1 and OD is about .75/.80-1.
Here's a link to pix.
Garth
1955 GMC 1st First Series Deluxe Cab
More pix on Photobucket
Tax the rich, feed the poor
Till there are no rich no more
Just black and white, rich or poor
Them and us, stop the war.
There should be a tag on the left side, lower rear of the tranmission with serial numbers and ID specs.
It certainly is a Clark though.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I can't wait to hear the answer on this one. Does it look like the same dimensions as the SM420? You would think if they fit right in these would be all the rage. I would love to have an overdrive in my NAPCO without making modifications. Odd shift pattern though.
The problem with these is that they are a non-synchronized transmission. Gears and other miscelanous parts are difficult to find. They weigh about 200 pounds and the shift pattern is ridiculous for people like me who don't deal well with changes.
If you can handle that, you can find them in a lot of bigger GMCs! It is a bit longer than an sm420.
Jeff
My 1953 Chevrolet
1947.1 Gallery
I'm assuming you have verified that it is indeed an OD. If it is an earlier model like the 202, 204, 205 and 207 it will be sliding helical gears with no synchros. However, they are rather easy to shift without a clutch because they are helical gears. If it is the later 264, 265 267 model it will have 2 synchros on the main shaft. If there is no tag, you can remove the shift cover and she if there are synchronizer assemblies between 4th and 5th and between 2nd and 3rd idler gears. One of the advantages of the shift pattern is the ability to go from 1st to reverse quickly to rock yourself out when you get stuck. As far as the shift pattern, you will get used to it. All of the 5 speeds of the 50's and 60's had goofy shift patterns. A Clark overdrive is hard to find and very desirable transmission in my opinion.
will the synchros be at all visible through the pto cover ?
I have a Clark 207VO to sell. 1-262-392-2989 or [email protected]
Marv.
After looking through a huge range of GMC Master Parts Books, I feel I can definitively say that is an early model 202, 205 or 207 model.
I don't believe the 265/267 will mount to a typical bellhousing, but instead to the SAE bellhousings. Your model will bolt to the same bellhousing as an sm420.
I doubt you could see the synchros through the pto cover.
Any chance finding that ID tag? Also, do you know what year this came out of?
I've seen a couple of these and don't think they are that rare. An old trucker like Ken would drive one of these things without blinking. I would struggle to learn the darn thing...
I sent one off with another bolter to be shipped to tcledermen and I doubt I will see any money from that after it's rebuilt, so they are around and for a reasonable price.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Not sure about the year. I know my Dad had it it the 54 GMC (that I am now working on)for a while in the mid 70's. The truck also has a 1955-1962 270 that he installed about the same time. I would guess that the 270 and 5 speed came from the same truck or bus. I do remember him double cussing(clutching) to down shift.
I'll check again for a tag and more info. next time I get over to the shop.
Thanks.
