| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Is there some sort of secret way to take the interior door handle and window wind up off? I've undone the screw and tugged a bit, but i don't want to tug to hard and brake something
Thanks, Josh | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | RUST, and 60 or so years of krud. Spray with some lube, wait a few days and repeat. It will come off! Make sure the screw is backed out enough, or just take it out all of the way.
....David
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I believe there are TWO screws on the interior window handle, or the door latch handle, I can't remember which. One covers the other. Check inside the hole to make sure. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I had the same experience Tom describes. 2 screws. I had the door off when I removed mine or it would have been pretty hard to see the second screw.
Chuck | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | Alright, ill look for the second screw and spray with WD40 while im at it. Thanks for the info! | | | | | Joined: Apr 2011 Posts: 174 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 174 | So after cleaning out all the crud that was behind the first screw, i found the second screw... now to find a small enough screwdriver to fit | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....a long slim screwdriver seems to work better for me. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Sears sells a professional series driver that is perfect for this job best $13 I ever spent. Craftsman Professional Screwdriver 1\4 in. X 12 in.Sears Item# 00947165000 | Model# 47165
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | I had a bunch of old, cheap screwdrivers laying around, so I took the skinniest one and ground it down to fit. That old wooden handled thing comes in handy for a lot of odd jobs. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I've got the same problem on my 50 AD,I guess i'll need to look for those second screws today. EDIT. Found them!
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
