7 members (3B, 68ironhead, Jon G, 2-Ton, Phak1, 49nut, Gray_Ghost), 64 guests, and 1 robot.
Topics128,049
Posts1,055,691
#844043 04/15/2012 9:02 PM
I have a 46 2 ton and it appears the hydrovac unit is missing, will the brake pedal be to heavy to stop the truck? should i get a new one? advice would be appreciated. thanks Matt
matt d #844102 04/15/2012 11:55 PM
62401
Hi Matt and welcome!
I think the answer to your question depends on what your intent is for the truck -- Are you intending to drive it loaded (heavy)) or just drive around in it as a fun truck (light)? If you plan on carrying loads, you may want to reinstall the hydrovac system. Short of completely upgrading the brakes, it may be your best and safest bet. The hydrovac units are available (rebuilt or kits). If you go that route, just be aware that using silicon brake fluid (DOT 5 here in the US) is not adviseable with the hydrovac system.
If you are mainly going to just drive the truck around for fun (i.e., light/empty) the brake system without the hydrovac system installed should be okay. I drive my '49 4400 around that way and the brakes were sufficient. Having the hydrovac installed on a trrck that will be driven relatively light will give you touchy brakes -- my '65 firetruck has hydrovac brakes and when I have no water in the tank (1,000 gallon capacity), I have to be careful on the brakes and have locked them up on more than one occasion -- which is sort of embarrassing ...
Good Luck!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I say this way to often, but the hydrovac will NOT make your brakes better. All it does is make the brakes easier to depress with your foot.
Jeff
My 1953 Chevrolet
1947.1 Gallery
matt d,
Rustednuts is right...
The Hydrovac only makes it easier on the driver.
Chevrolet stated that if you have a hydorvac in the systen and put a test gauge in the brake line, when the gauge reaches 1000 psi the pedal is providing 35% of the effort and the Hydrovac is providing the other 65%.
I like having the Hydrovac's in my trucks...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #844177 04/16/2012 5:01 AM
J M Offline
If it had a hydrovac, I would put it back on. Some of the older ones didn't have that much for brakes to start with. Also we are driving at higher speeda and in more traffic these days.
Jim
J M #844262 04/16/2012 5:55 PM
I had to temporarily disable by power booster
on the 59 fire truck and its a bear to stop.
Got to rebuild the hydro.
lcfman #844314 04/16/2012 10:48 PM
Just to confuse this thread some more with a pet-peeve of mine . . .
My '41 fire truck (either 1.5 or 2 ton - not sure which) has a factory-installed vacuum-assist canister for the brakes. In my mind, this is NOT the same as what everyone refers to as a "Hydrovac" - nor was it called such in the factory salesmen's book. Far less complicated, different principal, and different hook-up. Where a Hydrovac can be mounted anywhere on the truck, and just plumbed to the Master cylinder, the Vacuum-assist is a mechanical only deal, that must be mechanically attached to both the pedal and the master cylinder. No brake fluid ever goes to the vacuum assist unit, and it does NOT require "bleeding".
One uses vacuum to push the brake fluid to the cylinders (hence the "hydro"), while the other just uses vacuum to help push the pedal. (gross over-simplification?)
Anyway, this might affect your plans in terms of replacement of the missing unit. I'm guessing your truck, being the same model as mine-ish, may have had the vacuum assist, which mounts pretty much in-line with the master cylinder, just aft of it - if I remember correctly. Guessing a vac. assist would be harder to find. On the other hand, no reason a hydrovac couldn't be installed instead.
How's that for muddying the waters? ohwell
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Mikestem #844371 04/17/2012 3:06 AM
Just to add my 2 cents sooner or later a situation will occur where you will want all the brakes you can get.......like when that 5 year old kid runs out in front of you.
Worst case scenario yes, but s*%^t happens.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #844568 04/18/2012 1:39 AM
30 years ago I had a buddy that had a 56 Chevy school bus, the engine killed , he had no brakes and flew through a red light. There where probably other issues, but
I have the hydrovac on mine, best brakes on any antique I have ever had. Been playing with antiques quite awhile, most older. But the 47's brakes work well, though still not compared to todays vehicles. I would use it, the more brakes you got the better :-) good luck with yours.
Thanks for the response chaps. I would fit the hydrovac if I had one. I think I will just have to try it without and see how it goes. The truck is going to be driven unladen and probably for special occasions so will see what happens. Thanks Matt
matt d #845307 04/20/2012 8:07 PM
If it originally had one on it, i'd definitely put one back. Too dangerous out there on the road not knowing for sure if you're going to get stopped in time, or not. I drove a 2 ton Chevy flatbed around for a week, or so with a bad hydrovac, & had several close calls. It does make a big difference.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #845478 04/21/2012 5:23 PM
Does anyone know where to get one from. I presume mine had one because i have a pipe from the inlet up and across the baulkhead then down to the passenger side underseat area. I dont know were they were fitted does anyone know or have photos. Cheers Matt
matt d #845514 04/21/2012 8:45 PM
Check with Alretta Truck Parts. (508)788-9409. Ask for Geoff.
Spanky Hardy
1950 GMC 250 1-Ton
spanky #845719 04/22/2012 4:40 PM
You should also be able to get them from your local parts store. I don't know what the cost would be without the core charge for trade in, but at least you could pick one up locally.
Just make sure you get the right size. Too small and it won't make much of a difference. Too big and it won't work until you have the brakes 2/3rds to the floor.
Jeff
My 1953 Chevrolet
1947.1 Gallery
hi rustednuts, im in the uk and i dont think my supplier will have a clue wht im talking about.
Does anyone know what size I should have on a 160" 2 ton 46 stakebed then. without the original im lost.
Spanky where abouts is alretta truck parts, if i put the international dialing code in is 508 the state dial code?? Thanks Matt
matt d #845774 04/22/2012 6:34 PM
Hi Matt,
Duh... I didn't even see that! grin
Jeff
My 1953 Chevrolet
1947.1 Gallery
Jeff, do you know what size I would need?? Thanks Matt
matt d #845805 04/22/2012 8:48 PM
Alretta Truck Parts is located in Framingham, Massachusetts (508)is the State area code.
Spanky Hardy
1950 GMC 250 1-Ton
spanky #845807 04/22/2012 8:54 PM
cheers spanky !!
matt d #845859 04/22/2012 11:38 PM
Matt,
Let me look through my books and see if I can come up with some numbers.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Matt, I think you would be fine with a 1 1/2 to 2 ton sized unit. Unfortunately I do not know what the exact sizes are. The 2 1/2 ton sizes (GMC only, since I don't think Chevy made anything bigger than 2 ton in '46) and up look identical without perspective, but they are bigger when you set them side by side and I would be leary using one of them.
One I've seen was about 1" wider but the same length canister. Another was several inches wider and longer in the canister. All looking identical without a size perspective.
These things have been used in a ton of makes and models of cars, trucks, forklifts etc., all over the world. Lots of models out there...
Jeff
My 1953 Chevrolet
1947.1 Gallery
rustednuts #846354 04/24/2012 10:13 PM
you might try classic spares. www.classic-parts.co.uk they advertise brake and clutch parts, located kenton, Devon.
past parts ltd. [email protected]
Have you checked local newstands for Classic and Vintage Commercials or Heritage Commercials they may have useful leads.
Jim Carter Also sells Hydrovacs www.oldchevytrucks.com but he requires a core or core charge will apply.
