| | | Forums66 Topics128,086 Posts1,056,331 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84576 10/22/2007 9:00 PM | Joined: May 2005 Posts: 19 Apprentice | | Apprentice Joined: May 2005 Posts: 19 | I have been pouring rust penetrator into each cylinder for a couple of weeks, the engine will not budge.
Has anyone ever tried to pour near-boiling hot water down the thermostat housing (thermostat removed) to unseize a straight-six engine?
The theory, as I am told, is that the hot water will heat the exterior of the cylinder wall (via the water jacket) and thus, through expansion, break the hold the rust has on the piston rings.
My concern is that if I cannot completely drain the water from the engine (valve near bellhousing very is hard to reach) the block will crack when the remaining water freezes. Will cranking the water pump evacuate enough or all of the water?
"Nothing within the realm of the restoration process shall be alien to my experience"
#84577 10/22/2007 10:37 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | sambear,
I haven't heard of the hot water trick. It seems there wouldn't be much 'hot' left in the water by the time it made it into the dark recesses of the block...who knows!
Not coming from a freezing part of the country, this theory might be all wet, but if the water weren't constrained on all sides, it seems like it would grow in the unrestrained direction and do no harm to the block.
A plastic ice tray in the freezer doesn't rupture each time it's filled because the water can push upwards as it freezes and expands...does this sound right!
Stuart | | |
#84578 10/22/2007 11:10 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The only way to get all the water out of the block is to take off the water pump, open the rear block drain, and tilt the engine until it runs dry. Cranking the water pump leaves about 1/2 the water in the block and could/will damage the block if it freezes. However, you could add antifreeze to it later and circulate it around.
I'm pretty sure it won't work though. You will have to add about 40,000 btu's of heat to bring a block up to operating temperature, which is about 60 gallons of hot water.
Besides, its probably the rings which are siezed to the cylinder bores, and those have a gap so they will just expand and contract with the cylinder walls.
#84579 10/22/2007 11:17 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can get most of the water out by draining the radiator & raising the rear of the truck real high. You should be able to drain the block. You can either remove the plug or the petcock & poke a wire up in the hole if it is pluged up. If you have ever pulled the head on an engine that was stuck real bad you will see you are waisting time fooling with it. They are full of corrosion. If you do free it up it won,t be any good. It,s probably time to pull it out & rebuild it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#84580 10/23/2007 5:17 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | If you're bound to try it, use hot coolant mixture that won't freeze, Scott | | |
#84581 10/23/2007 6:13 AM | Joined: Sep 2007 Posts: 11 Apprentice | | Apprentice Joined: Sep 2007 Posts: 11 | sounds like its time to tear it down to me. you've spent a few weeks trying to get it turn, it only takes a few hours to take the head off. if its stuck that tight, the chances of it running, even if you get it broke loose is pretty slim.
it's not a brick, it's cruise control.
#84582 10/23/2007 4:30 PM | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | I agree that a little hot water wouldn't do much. But its worth a shot. But I also think you pull the head and see what your dealing with. Also ever think about carefully heating it with a torch just ever so gently and carefully not to burn or melt anything. That has broke nuts loose before this is just on a larger scale  | | |
#84583 10/23/2007 9:39 PM | Joined: May 2005 Posts: 19 Apprentice | | Apprentice Joined: May 2005 Posts: 19 | A friend is trying to get me to boil a 50:50 mix of anti-freeze and water and pour that in. He thinks that will develop a little more heat and provide less concern if left in the water jacket.
Thoughts?
#84584 10/25/2007 2:04 AM | Joined: May 2007 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 36 | When i have a motor that is stuck i use CRC penetrating oil and it works every time.you need to fill up the cylinders and let it sit for a week and hit the starter ever once in a while It will brake loose.I had a 350 that sat for 25 years and was frozen solid and i got it running again CRC works man try it.P.S DO NOT PUT THE SPARK PLUGS IN IF YOU FILL THE CYLINDERS BECAUSE YOU COULD HYDRAULIC A ROD IF IT TURNS OVER!FLUID DOES NOT COMPRESS.Hope you get it un frozen. | | |
