0 members (),
74
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84417 10/16/2007 3:35 PM | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I'll be taking the engine and tranny off soon so the frame can get sandblasted. I'd like to make a wooden frame for the engine to sit on temporarily. Has anyone made one before? If so, any plans, measurements, templates...etc? It's for a 235 with a SM420 tranny. I'd like to keep them bolted together on the wood frame if possible.
Thanks in advance! | | |
#84418 10/16/2007 4:04 PM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You should be able to remove the sheet metal cover over the flywheel. then set the whole thing on wood blocks right there, it's wide and flat so it sits pretty stable. Also place a block under the front motor mount. Not easy to move like that, but will keep it upright and not damage the oil pan.
Grigg | | |
#84419 10/16/2007 4:13 PM | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Ron, What I did was use a 4x4 cut 2ft. in length across the front of the engine and used lag screws to bolt the plate down. Mine just sat on my garage floor making sure it was out of the way. My 216 with bell housing and trans attached however,is riding in a large garden wagon I bought from Lowe's for $75.It has inflateable tires and removable or fold down sides. It's very sturdy and because of the larger tires can be pulled across hard or soft surfaces. It tows with my lawn tractor too. Well worth the money.
Drew
#84420 10/16/2007 5:11 PM | Joined: Jun 2006 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 91 | I made a wooden dolly that was a perfect fit for the inside leg diameter of my engine hoist. The height is just slightly higher for clearance incase something is wider. I made this to be multifuntional and not just for engines. On the side I put some I-bolts that would allow me to secure the engine. It is plenty strong enough to run the engine on it or use it to sit something heavy on using the hoist. Sorry I don't have a picture of it maybe i'll take one this week.
Dana | | |
#84421 10/16/2007 6:24 PM | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | WOW! All great ideas...I was thinking maybe putting heavy-duty casters on the bottoms as well. Anyone know what the combined weight would be for the engine and tranny? I used 4" casters for the cab dolly I built and it holds great. Engine and tranny weight -vs- cab weight I'm thinkin should be close to the same. | | |
#84422 10/16/2007 6:31 PM | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Ron, I putzed around and made one a few years ago out of 2" square stock. Never got around to putting the tranny mounts on eventhough I made them up. Pics below. Dan http://rides.webshots.com/photo/1512705220071274430hzqWNh | | |
#84423 10/16/2007 6:52 PM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | quick easy and too simple...but plenty of times ive set an engine on a spare tire and wheel... dont work too bad...used to haul them in the back of a pickup that way too... or just a couple of old tires works also.
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#84424 10/16/2007 9:29 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 |
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#84425 10/16/2007 10:13 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I use a pair of 4x6's as well. I even started my 302 up when it was sitting on them. I got it home by nailing the whole thing to the wood bed of my trailer.
#84426 10/17/2007 3:09 PM | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | I got an old pallet from the lumber yard, reinforced the deck with OSB, and mounted the engine/transmission level with various blocks. I then lagged bolted it down and wrapped a chain around it to make sure it stays. The best thing is I can use my tractor with some rear forks to move it around. | | |
#84427 10/17/2007 6:40 PM | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have used the wooden crate(modified to fit)that a "crate motor " comes on.You can find them behind most Chevy Dealers in a heap.Just ask the Servive Department if you can have one or two.When you are done they make good firewood.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#84428 10/18/2007 1:00 AM | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | i just set mine on a piece of cardboard, propped a couple of boards under the motor mounts to keep it from falling over if someone was to yank on it.
#84429 10/19/2007 3:41 AM | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | I used four jack stands, one at each corner of the engine on the oil pan flange. Can use some folded cardboard or a couple wood srips to avoid bending the pan lip. It sat nice and stable for quite some time that way. Altho, since it was in an area it might get bumped I left the hoist hooked up with the slack out of the chain. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
#84430 10/21/2007 9:14 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | What gtow69 said, Any dealer is usually glad to get rid of them,Especially after The Town/Authorities come down on them to clean up their act. Regards...... | | |
