7 members (UtahYork, MickeyP, Gdads51, Cletus1950, TexasJim50, Hotrod Lincoln, baldeagle),
105
Mod | | | Forums66 Topics128,179 Posts1,057,068 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Took a 4 hr road trip and bought a '51 this morning. I think I got a good deal for less than $1500. - clean title - title serial number matches number on door jamb tag - usual dents and rust - original radio (will upgrade to electronic) - original bench seat i think (will swap with 60/40 split) - bed has a solid steel plate covering planks (not sure what to do with this) - engine runs and code is hard to read but it looks like a HAM or HEM xxx (will eventually drop in a V8) link below: http://s848.photobucket.com/albums/ab41/malibu67/1951%20Chevy%20Truck/
1951 Chevy 3100 | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | | | | | | Joined: Dec 2011 Posts: 73 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 73 |
Wayne S. Colorado Springs, CO
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I think you did good to. It looks like all those coats of paint may have helped to preserve it. Let us know how we can help. | | | | | Joined: Feb 2012 Posts: 60 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 60 | Thanks for you offer to help as i am sure I will need. I recently completed restoring a 67 Chevelle (also on the photobucket page) so I think I am ok with patch panels, and some light metal work. first thing I have to do is run a subpanel to my garage as I only have 1 outlet. I need 220V to run my compressor and install heater.
I know I will need help on the power train so I have a lot of reading to do. I do not want to re-invent what many have already done. I know I want to drop in a V8 and a manual tranny. So from reading, I hope to figure out what I need to make it happen (what tranny and what rear) and then its a matter of finding it locally.
