3 members (Gray_Ghost, DadsFirstPickup, 53 green 1- ton), 51 guests, and 2 robots.
Topics128,130
Posts1,056,713
Members48,454
mo
Offline
thinkin about putting an x-member in place of center crossmember. something like this. this would give me an opportunity to put a drive shaft loop in and i would have four supports to the bottom rail instead of the rusted out two that were there. any opinions or ideas would be great. thanks MO
MO's 1951 chevy 3100 resto mod project
Mo, I'm not the expert but I see no harm done. compared to the orignal chassis wouldn't the X member make it sturdier?
Hey, it accomplishes what you need I think its a good idea. Besides, someone has to be the first to try new things!!
Chevy frames in the 30's had an XK in the middle of the frame and the torque tube went right through the middle, just like a drive shaft loop.
I see no harm in doing it, but I'm not a chassis engineer either.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
mo
Offline
i think i will just build a new k member with driveshaft loop incorporated. then i will tie that to the bottom rail somehow. might have to build a mockup out of wood for this one first. to see if it will work. cant wait for some more spending money as i am broke. later mo
