3 members (greenie-reddy, Hotrod Lincoln, Dusty53), 161 guests, and 3 robots.
Topics128,101
Posts1,056,172
Members48,436
#841079 04/04/2012 12:22 PM
F Online: Content
I have picked up an original Harrison radiator to serve as a replacement for the current radiator in my '48 Chevy 1/2 ton. I want to clean it up and paint it. Any advice on prep and proper paint to use would be appreciated. Thank you!
rustoleum flat black should work just fine.....but I'm sure folks like Eastwood have something to sell you for 20 bucks a can.
I'd be careful cleaning it. Don't want to put anything corrosive on it since your not taking it a part. Since its sort of hidden I'd clean it with some soap and water, maybe run it GENTLY with a soft nylon brush to get the bugs juice off and spray on the flat black.
F Online: Content
Does this need to be a high heat paint?
No, regular Rustoleum will work fine.
I painted the fan and original Harrison radiator in my '54 last month. I used Rustolium Black Semi Gloss Protective Enamel on the radiator and Rustolium Black Semi Gloss Automotive Enamel on the fan. One light coat and two medium coats, the last a little wetter. (Both paints have the same sheen level, but I had more "Protective Enamel" than "Automotive Enamel", so that's what I painted the radiator with.) Don't know how it will stand up against heat. I only painted the shell / not the fins. I tested Duplicolor Ford Semi Gloss Black Engine Enamel, but it has a slight grey tint that I did not like for the radiator and fan.
I used laquer thinner to remove the old paint. Buffed the brass with a dry towel. Masked off the fins so they didn't get painted. Primed with two coats of Rustoleum Self Etching Primer and lightly knocked down any rough spots with a ScotchBrite pad.
No room in the garage to paint the radiator. So I built a "paint booth" outside with a couple 6' ladders, a 2X4 and two shorter pieces for roof rafters, a plastic drop cloth "tent" to protect from dirt and leaves, and a few clamps to hold it together and to close the tent. It worked great.
> "Paint booth" frame
> "Paint booth" open
> "Paint booth" closed
> Radiator hung in the garage to dry
> Painted and installed front
> Painted and installed rear
- Lonnie
My '54 3104
Good tips your getting here. If your going for an original look I would stick with the semi gloss or it's also called satin black.
Before being too dismissive of specialty radiator paint, there's something to think about - it's designed to go on thin. You don't want too much paint between the air and your radiator fins, or clogging up the space between the fins. It cuts down on efficiency.
1954 GMC De Luxe COE
Buckstruck -
For the brands that I tested, semi gloss black is shinier than satin black.
Here are the results of my unscientific visual test:
GLOSS
RANK / / BRAND / / PART # / / DESCRIPTION / / SHEEN-COLOR (Notes)
1 / / Rustoleum / / 252462 / / Automotive Aerosol / / Gloss Black
2 / / Dupli-Color / / DE1613 / /Engine Enamel / / Gloss Black
3 / / Rustoleum / / 209584 / / Automotive Aerosol / / Semi-Gloss Black (Similar to R Semi Gloss)
4 / / Rustoleum / / 7798830 / / Protective Enamel / / Semi Gloss Black (Similar to R Auto Semi Gloss)
5 / / Dupli-Color / / DE1635 / / Engine Enamel / / Ford Semi Gloss Black (Slight grey tint)
6 / / DuPont / / A-5099S / / 1K Bumper & Trim Black / / DuPont Satin Black (Slight grey tint)
7 / / Rustoleum / / 7777830 / / Protective Enamel / / Satin Black
8 / / Dupli-Color / / DE1634 / / Engine Enamel / / GM/CHRY Low Gloss Black (Flat, slight grey tint)
- Lonnie
My '54 3104
Thank you Lonnie, I have learned something new.
Isn't radiator paint a water based product that helps with cooling?
F Online: Content
This is a lot of good info. to work with. Thank you to all who have tapped into this--much appreciated!
LUKE
