| | | Forums66 Topics128,012 Posts1,055,311 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#84087 10/11/2007 5:05 PM | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | When changing 1941 ½ ton Huck brakes to early 50’s Bendix brakes, do I need to ugrade the Hub along with the backing pate and other brake parts? | | |
#84088 10/11/2007 5:25 PM | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | The obvious things are the brakes, backing plate and all related little brake parts. Id assume you can use the hubs.
Can you get some pics when you do this, as Im real interested to see how it turns out as I plan to do the same on my coe at somepoint in the future.
Jeff | | |
#84089 10/12/2007 3:06 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Seems there are two theories on this in regards to an AD anyway. Some say you can use the existing hubs others say you have to use the original. There is a Tech Tip about this on this site and another on a different site. | | |
