1 members (baldeagle), 36 guests, and 7 robots.
Topics128,014
Posts1,055,327
Members48,419
#84061 10/11/2007 2:37 AM
Hey guys,
I want to replace my spark plug wires on my 51, 235. This is a 6 volt system Is there any difference between 6 and 12 volt wires. There is with the battery cables?
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#84062 10/11/2007 2:43 AM
Glenn,
No difference. I think you want a set of solid wires as opposed to carbon core or resistor wires (?). If you have a radio in the truck you actually listen to, wire type might be a consideration.
Stuart
#84063 10/11/2007 4:34 AM
Thx stuart
1952 Chevy 1/2-Ton
#84064 10/11/2007 12:58 PM
I bought Moroso black wires in a do it yourself kit. Cut all to length to make it look nice. Great performance and no radio static (that is when I can hear the radio over the engine and dual exhaust noise.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#84065 10/11/2007 12:59 PM
Resistor "wire" is probably the only choice you need to consider. Metal-core wires create problems such as contact erosion inside the distributor cap, burning of the rotor tip, and more rapid spark plug electrode wear. They also create radio-frequency interference, but it's usually only evident if you're listening to the AM radio. The resistance wire is actually a graphite-impregnated piece of nylon string. Maximum resistance value of the supressor wire is 1,000 ohms per inch.
