| | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Pulled my axles(Spicer 60) to replace bearings and seals. Found a slight amount of grit in the axle tube. I want to make sure and get any foriegn material out of it. If I pull the cover and drain the rear, whats the best way to flush it out, including the axle tubes?
Thanks.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | May sound crazy but attach a wire brush to a stick and rub it in and out of each axle half. I mixed up some purple power and "flushed" mine. You would also be surprised what a hose pipe with a nozzle on it will do to "move" debris out of the housing. It surely will not rust. I did use a can of brake cleaner inside the center section.
If you don't want to go to all that trouble just soak a rag with some cleaner and run it through the housing....all depend on just how bad it is. | | |
