1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#840245 03/31/2012 11:28 PM
Pulled my axles(Spicer 60) to replace bearings and seals. Found a slight amount of grit in the axle tube. I want to make sure and get any foriegn material out of it.
If I pull the cover and drain the rear, whats the best way to flush it out, including the axle tubes?
Thanks.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
jmoore #840299 04/01/2012 3:43 AM
May sound crazy but attach a wire brush to a stick and rub it in and out of each axle half. I mixed up some purple power and "flushed" mine. You would also be surprised what a hose pipe with a nozzle on it will do to "move" debris out of the housing.
It surely will not rust. I did use a can of brake cleaner inside the center section.
If you don't want to go to all that trouble just soak a rag with some cleaner and run it through the housing....all depend on just how bad it is.
